Block on an incline connected to a mass cord pulley 26˚. acceleration?
The problem involves a block on an inclined plane connected to another block by a cord over a pulley. The incline is at an angle of 26 degrees, and the coefficient of kinetic friction is given. The objective is to determine the acceleration of both blocks.
  • Mixed
  • Participants discuss the relationship between the tension in the cord and the acceleration of both blocks, suggesting the need for two equations to represent the forces acting on each block. Some express uncertainty about how to start the problem, while others reference a specific tension value provided by their teacher to simplify the problem.
The discussion includes various attempts to approach the problem, with some participants providing equations and others questioning the role of friction and the direction of forces. There is no explicit consensus on the method, but multiple interpretations and approaches are being explored.
Participants note that they have not covered this type of problem in class, and there is mention of a teacher's guidance that may influence how the problem is approached. The problem is also sourced from an online platform, which may affect the understanding of the context.
aly1201
block 1 lying on an inclined plane is connected to block 2 by a cord passing over a pulley.
the coefficient of kinetic friction between block 1 and the plane is .21 and block 1 and 2 are 2.6 kg. As block 2 moves down, determine the magnitude of the acceleration of block 1 and block 2 given θ=26˚ (in the diagram, block 2 isn't on a plane, just hanging)
F=ma?
9.8sin26?
we never learned this type of problem in class, but i found an equation in the back of my textbook g (m1sinθ-m2)/(m1+m2)
i'm guessing m1 and m2 are mass1 and mass2 so when i solved it i got 1.16. this problem is from an online site masteringphysics.com and eventually i guessed 1.8 and it was right, but i'd like to know how to actually do the problem. don't need to answer right away
In this problem, the tension in the cord and acceleration of m1 and m2 must be the same. Wright 2 equations, one for m1 and other for m2.
If a is the acceleration then
T-m1*g*sin(theta) - mu*m1*g*cos(theta) = m1*a
m2*g - T = M2*a
Solve for a.
There is also the friction force. And the trouble of which way it is acting.
I get a = 3.66.
Would appreciate seeing how you get the 1.8.
i really don't even know how to start, our teacher said he might show us on wednesday. he sent this email out to help us because so many people were emailing him questions.
"replace the mass 2 force with a tension in the connecting rope of 20.7N. This would be the force applied to mass 1. Using this value allows you to solve the problem without any further concern of the effect of moving mass 2 on the acceleration of mass 1. This greatly simplifies the solution of the problem."
