What is the Magnetic Field at the Center of a Current-Carrying Loop Segment?
The magnetic field at point A, the center of a current-carrying loop segment, is calculated based on a circular arc with a radius of 4 cm and a current of 2.5 A. The arc spans from 60° to 360°, representing 5/6 of a complete loop. The magnetic field contribution from the vertical section is determined using integration of dx * sin(theta) / r^2, where dx is a small element of the vertical conductor. The calculated magnetic field magnitude at point A is approximately 3.27 x 10^-5 T.
  • Understanding of magnetic fields generated by current-carrying conductors
  • Knowledge of calculus, specifically integration techniques
  • Familiarity with trigonometric functions and their applications in physics
  • Basic principles of electromagnetism, including Biot-Savart Law
  • Study the Biot-Savart Law for calculating magnetic fields from current distributions
  • Learn about integration techniques in calculus, focusing on applications in physics
  • Explore the effects of different loop geometries on magnetic field strength
  • Investigate the relationship between current, magnetic field strength, and distance from the conductor
Students in physics, electrical engineers, and anyone interested in understanding the principles of magnetism in current-carrying conductors.
jromega3
A loop carries current I = 2.5 A in the x-y plane as shown in the figure above. The loop is made in the shape of a circular arc of radius R = 4 cm from qo = 60 ° to q = 360 ° . The loop is completed by horizontal and vertical sections as shown.
What is BA, the magnitude of the magnetic field at point A, the center of the circular arc?
For the loop part...
Well, that's it if it were a complete loop, but this is 300/360, or 5/6 of a loop. So I take that and divide by 1.2 and I get 3.27e^-5.
Not sure about the other ones. My calculus is rusty at best.
It's hard to visualize maybe, but it's basically a circle from the 60 degree above the horizon all the way till the end, with a straight line going down to the horizontal center line and then a line connecting that line to the 0 degree mark on the curve.
As always, any help is appreciated.
Now you have to find the field due to the vertical section of the loop. By trig. you can see the length of the vertical section is 2sqrt3. The horizontal section does not produce any field at the centerIn the relevant equation take the integration of dx*sintheta/r^2 where dx is a small element of the straight vertical conductor, r is the distance of the element dx from the center and theta is the angle between the conductor and r.
9K
