How Fast Will the Flower Pot Hit the Ground?
  • Thread starter Thread starter tomboi03
    Falling Window
The discussion focuses on calculating the velocity of a flower pot as it hits the ground after being dropped from a height above a dorm window. Key variables include the time the pot is visible (t), the vertical length of the window (Lw), and the acceleration due to gravity (g). The user, tomboi03, struggles with the correct application of kinematic equations and is advised to utilize the formula for accelerated motion that relates distance, initial and final velocities, and acceleration. The correct approach involves using the distance formula and then applying the velocity formula to find the final velocity upon impact.
  • Understanding of kinematic equations in physics
  • Familiarity with concepts of acceleration and velocity
  • Knowledge of gravitational acceleration (g)
  • Ability to manipulate algebraic equations
  • Study the kinematic equations for uniformly accelerated motion
  • Learn how to derive velocity from distance and time in physics
  • Explore the concept of free fall and its implications in real-world scenarios
  • Practice solving problems involving initial and final velocities in vertical motion
Students studying physics, particularly those focusing on mechanics and kinematics, as well as educators seeking to clarify concepts of motion under gravity.
tomboi03
As you look out of your dorm window, a flower pot suddenly falls past. The pot is visible for a time t, and the vertical length of your window is Lw. Take down to be the positive direction, so that downward velocities are positive and the acceleration due to gravity is the positive quantity g.
Assume that the flower pot was dropped by someone on the floor above you (rather than thrown downward).
So the known variables are... t, Lw, and g.
If the bottom of your window is a height h above the ground, what is the velocity vground of the pot as it hits the ground? You may introduce the new variable vb , the speed at the bottom of the window, defined by
Vb=Lw/t+(g*t)/2.
Express your answer in terms of some or all of the variables hb, Lw, t, vb, and g.
I have these equations already... but i don't know where to go about from here...
hb=vb+1/2(gt2)
the equation given...
vg=vb+g*t
vb=1/2*g*t2-hb
I keep missing one variable... and I'm getting frustrated... :'(
Please help me out.
Thank You,
tomboi03
Okay, so you know the speed at the bottom of the window, h above the ground. You just have to find the speed after it falls that distance h.
"hb=vb+1/2(gt2)" doesn't make sense - it says a distance equals a velocity.
"vg=vb+g*t" would be correct if t was the time to fall the height h, but it is not the same as the t in the question.
"vb=1/2*g*t2-hb" has a distance subtracted from a speed, which is impossible because the units clash.
What you really need here is an accelerated motion formula with initial and final velocities, distance, but not time. If you can locate one on your list, it will solve the question instantly. Failing that, you must use a distance formula like
d = volt + .5at^2 to find the time to fall the height h. Then use a velocity formula like
V = Vo + at to find the velocity after that time.
  • · Replies 17 ·
  • · Replies 25 ·
