Calculate Torque in Gear System After Motor Power Cut Off
The discussion revolves around calculating the torque in a gear system after the power supply to a motor is cut off, specifically focusing on the time it takes for the system to come to rest. The context includes mechanical principles and the effects of friction in a universal motor setup.
  • One participant inquires about the torque in a gear system and the time to stop after the motor is turned off, providing specific values for torque and RPM.
  • Another participant suggests using the decelerating torque equal to the steady state torque to calculate deceleration and stopping time, framing it as a simple mechanics problem.
  • A different participant challenges the previous assertion, stating that the decelerating torque is not equal to the steady state torque after the motor is off, but rather is determined by frictional torque, which they seek help to calculate.
  • Another participant clarifies that the steady state torque from the motor equals the load torque, and when the motor is off, the load torque remains while the motor provides no torque, emphasizing the role of friction in the stopping process.
  • One participant notes a potential language barrier affecting communication in the discussion.
Participants express disagreement regarding the nature of the decelerating torque after the motor is turned off, with some asserting it is equal to the steady state torque and others arguing it is determined by frictional forces. The discussion remains unresolved.
Participants mention the need to calculate frictional torque, indicating that assumptions about friction may affect the analysis. There is also a suggestion that friction remains constant, which may not hold true under varying conditions.
vikramvv
What will be the torque in a gear system after the motor get off. If so wat time it will take to stop.
For example say if a motor is operating at a torque of 0.075Nm with 6000 rpm and the output gear rotate with a torque of 25Nm with 18 rpm. After some time motor is not experiencing any torque also. motor power supply is cutoff. so motor will rotate at no load. So how much time it will take to come to rest.
Motor used universal motor.
Assumption: steady state
If motor is turned off now, it has a decelerating torque equal to whatever it was giving in at steady state, use T=I*alpha, that gives the deceleration, use equation of motion with initial angular velocity as omega(something that you had) & final angular velocity as 0, you get the time.
Its a simple mechanics problem, not some electric motor related engineering thing(not being sarcastic, am just tellin)
What you have told is unfortunately wrong.
After the motor has been turned off, the decelerating torque cannot be equal to what it was giving in steady state ( Just because there is no more supply to give the torque).
The decelerating torque is actually the frictional torque contributed by friction on shaft and between gears.
Rest of what you have told is right.
But what I don't know is how to calculate the frictional torque.
After that, it is just T= I*alpha as you told.
So if anybody can help with frictional torque, you are most welcome...
Thanks
steady state torque from the motor = torque requirement of load.
When motor goes off, torque from motor = 0, load torque on the shaft = still steady state torque from motor. friction was already present, so it was a part of steady state torque, just assume friction stays constant & doesn't vary with shaft speed.
Think of it like this, if you are holding the shaft with your hand & the motor is running, motor provides as much torque as your hand puts in. When power is turned off, you are still holding the shaft with same force as before(same load), you are retarding it more rapidly. I guess, you can imagine which system ll stop earlier, a motor with load at shaft or a motor with free shaft(in this case, friction at bearings(& a bit of air drag) causes the motor to slow down).
First, I meant the numerical value of torque, not the source of torque. Second, one should be a bit more polite if confused. :smile:
  • · Replies 17 ·
  • · Replies 19 ·
