Conversion of particle fluence to Krad
  • Context: Graduate
  • Thread starter Thread starter lekshmi
    Particle
The discussion revolves around the conversion of particle fluence, specifically protons and electrons, into radiation dosage measured in Krad or Gray. Participants explore the relationship between the number of particles per square centimeter and the energy absorbed, considering the context of radiation effects on materials like InGaAs pin photodetectors.
  • Experimental/applied
  • One participant inquires about converting a proton fluence of 6.2 X 10^11 particles/cm^2 at 50 MeV into Krad.
  • Another participant notes that doses are defined as energy absorbed per kilogram of matter, suggesting assumptions about the absorption characteristics of the material involved.
  • A participant mentions specific fluence values and their corresponding dosages in Krad from a paper, indicating a potential relationship between particle energy and dosage.
  • There is a challenge regarding the material dependency of dosage measurements, with a participant asserting that the energy per mass is material dependent.
Participants express differing views on how to approach the conversion of particle fluence to radiation dosage, with no consensus reached on the methodology or assumptions required for accurate conversion.
Participants highlight the need for assumptions regarding the absorption of radiation by specific materials, which may affect the conversion from fluence to dosage. The discussion also reflects uncertainty about the applicability of provided figures from literature.
This discussion may be useful for researchers and practitioners working in radiation physics, materials science, and engineering fields, particularly those involved in radiation effects on electronic components.
lekshmi
suppose in a radiation environment , the radiation dosage is given in terms of no: of particles per square centimeter, how will we convert it in terms of rad or kilorad or gray?
For eg: let the proton fluence be 6.2 X 10^11 /cm^2. the energy is 50 MeV. how can we express it in terms of Krad?
I thought those doses where [energy absorbed per kilogram of matter]
e.g 1 Gray = 1J/1kg matter
So one has to make assumptions on what is happening to that radiation fluence, assuming that it impinges on water and that it is fully absorbed or whatever.
actually i am dealing with the radiation effects of certain materials like InGaAs pin photodetector. in 1 square centimeter of that material proton fluence of 6X10^11 particles are falling.i want to get the dosage in terms of Krad or gray. In one paper it was given that 6.2 X 10 ^11 protons/ cm^2 of energy 50 MeV corresponds to 100 krad.
similarly 2 MeV electrons of fluence 4.1 X10^12 corresponds to 100 Krad.
and 100 MeV electrons of fluence 3.3 X 10^12 also corresponds to 100 krad.
how can i relate all these figures?
what paper? a paper related to that particular detector?
6.2 X 10 ^11 protons/ cm^2 of energy 50 MeV is 5 Joules/cm^2
I mean, the dosage is measured in energy per mass, and it is material dependent.
  • · Replies 25 ·
  • · Replies 36 ·
10K
  • · Replies 62 ·
13K
  • · Replies 0 ·
