Thermodynamics: Enthalpy of Sucrose
by Thyferra2680
Tags: enthalpy, sucrose, thermodynamics
Thyferra2680
Thyferra2680 is offline
#1
Feb8-09, 03:16 PM
P: 7
A sample of sucrose, C12H22O11, with mass 0.1265 g, is burned in a bomb calorimeter initially at 298 K. The temperature rises by 1.743 K. To produce the same temperature increase with an electrical heater in this apparatus, it is found to require 2.0823 kJ of energy.
(1) Determine Δ H0 (298) for combustion of sucrose.
(2) Use data in Table 19.2 to calculate Δ H0 (298) for combustion of sucrose, and compare
your answer to (1).
(Table 19.2 states that Sucrose has a Molar Enthalpy of formation of -2220 kJ/Mol)
2. Relevant equations
DeltaH = DeltaU + Delta n R T
DeltaH = DeltaU + P DeltaV
U = Heat(constant v)
H = Heat(constant p)
Molar mass of Sucrose
Personal Assumption (Ideal gas?)
3. The attempt at a solution
So, I've tried a few things.
First I tried saying that the combustion of Sucrose is from 12 mol O2+ 1 mol Sucrose = 12 mol CO2 + H2O, thus delta n = 11 moles. Delta U is the energy from the problem statement because in the calorimeter the combustion is taking place at constant volume.
But if I use this, then my Delta H is in terms of a constant volume measurement, which apparently isn't what we're supposed to use, because Delta H is usually calculated via constant pressure. Even then, the molar value of Enthalpy is 79314.6 kJ/mol, which even for a big molecule, seems absurd compared to the value in the table for the next part of the problem.
I think the big part is that I'm assuming Ideal gas for the product gases. Is there any way out of this mess?
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
chemisttree
chemisttree is offline
#2
Feb9-09, 03:32 PM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,725
Start by calculating the heat of combustion of sucrose in the bomb. How many moles of sucrose were burned? How much energy was released? What is the energy per mole?
In your expression for Delta U, what is the value of the term 'P Delta V' in that expression?
Register to reply
Related Discussions
Prof teaches Statistical thermodynamics in a Classical Thermodynamics class Academic Guidance 10
Thermodynamics Temp/Enthalpy in HTS Nuclear Engineering 4
Enthalpy of Formation vs. Bond Enthalpy Biology, Chemistry & Other Homework 7
Enthalpy of Dissolution vs. Enthalpy of Solution Biology, Chemistry & Other Homework 4
Thermodynamics problem; App of 1st law, work, adiabatic processes, and enthalpy Engineering, Comp Sci, & Technology Homework 3
