Thread Closed
Tricky semi-infinite integral
Share Thread Thread Tools
Feb9-09, 01:59 AM   #1
I am trying to integrate
[tex]\int^\infty_0 \frac{e^{-tp^2}}{{p^2+b^2}} cos(pu) dp[/tex].
2. Relevant equations
I know that
[tex]\int^\infty_0 \frac{e^{-tp^2}}{{p^2+b^2}} dp= \frac{\pi}{2b}e^{tb^2}erfc(\sqrt{a}x)[/tex]
3. The attempt at a solution
I rewrote the problem in terms of the complex exponential and reduced the integrand to a form similar to
[tex]\int^\infty_0 \frac{e^{-tp^2}}{{p^2+b^2}} cos(pu) dp= Re(\int^\infty_0 \frac{e^{-t(p-s)^2}}{{p^2+b^2}} dp)[/tex]
where s is complex but I was stuck here. Any suggestions would be much appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb9-09, 11:27 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
The integrand is an even function of p, so I would divide it by 2 and integrate over [itex](-\infty ,\infty )[/itex]. Then I would try to use the Residue Theorem. Are you familiar with that result?
Feb9-09, 05:09 PM   #3
Yes I am familiar with it however not in this form. Are you suggesting forming a curve on the complex plane which encloses the points p=+/-ib. The integral over this curve would equal 2*pi*i* Sum of residues?
Feb9-09, 05:52 PM   #4
Recognitions:
Not quite. If the real axis is part of the contour, then you would close it with a semicircular arc in the upper half plane (or the lower half, your choice). In either case the contour only encloses one of the poles, not both.
Feb9-09, 05:58 PM   #5
Cool. Thanks for the help! It was a very nice step.
Here is the solution for anyone interested:
[tex]
\int^\infty_0 \frac{e^{-tp^2}}{{p^2+b^2}} cos(pu) dp = \frac{\pi e^{tb^2} cos(ibu)}{2|b|}}[/tex]
Feb9-09, 08:48 PM   #6
Hi Tom. As my b is a real number, for the case b=0 this doesn't work. I want to find out
the limit as b-> 0 of b * integral. I know that it is equal to zero but I am having proving this. All I really have to do is show that the integral with b=0 is finite.
Any suggestions?
Feb10-09, 10:18 AM   #7
Recognitions:
How about setting b=0 in the original integral and calculating the residue of the pole of order 2 that results? You'll need a different contour of course.
Feb10-09, 05:28 PM   #8
I ended up just using L'Hopital's rule and it came out quite easily. Thanks Tom you were a lot of help! Very much appreciated.
Thread Closed
Thread Tools
Similar Threads for: Tricky semi-infinite integral
Thread Forum Replies
Finding the Electric Field of a non-uniform Semi-Infinite Slab of Charge Introductory Physics Homework 0
semi infinite line charge? Introductory Physics Homework 1
Integral of (z^2)dz around a semi-circle in the y >= 0 region. Calculus 9
Help! Two fused semi-infinite rods - hard integral Calculus & Beyond Homework 0
PDE semi-infinite strip Calculus & Beyond Homework 2
