Percent% Errror Quoted for Electrical Components. What is it?
by Phrak
Tags: components, electrical, errror, percent%, quoted
Phrak
Phrak is offline
#1
Feb9-09, 03:33 AM
P: 4,513
(Where do I post electrical engineering homework questions? I'm home. I'm working. OK, maybe I'm not really working.)
Manufacturers quote a percent variation from nominal value for their parts. What does this percent error even mean??
For a 5% error, does this mean that each and every part is within 5% of the quoted value. Is the distributions flat, or is it Gaussian in shape?
If the manufacturer also sells a 2% version, does this mean that the 5% parts will have the middle 2% missing as these parts are selected-out?
Phys.Org News Partner Engineering news on Phys.org
Researchers propose network-based evaluation tool to assess relief operations feasibility
Large streams of data warn cars, banks and oil drillers
Engineering student developing traffic forecasts
MATLABdude
MATLABdude is offline
#2
Feb9-09, 05:15 AM
Sci Advisor
P: 1,724
Quote Quote by Phrak View Post
I believe that if you're quoted 5%, the manufacturer guarantees that the resistors are within 5% of the nominal value (at some given temperature)--otherwise, they'd go into the next resistor size! I seem to always get better though.
The reason you don't see the 2% chopped out of the 5% (and the 1% chopped out of the 2%, and so forth) is that resistors are sold in various series. There are more 2% nominal resistor values available (E48) as opposed to 5% (E24) and 10% (E12):
http://en.wikipedia.org/wiki/Preferred_number
With better manufacturing tolerances, you can always sell higher-tolerance resistors as lower ones.
Phrak
Phrak is offline
#3
Feb9-09, 03:06 PM
P: 4,513
Quote Quote by MATLABdude View Post
That makes some sense. It may depend on the manufacturing process; upon whether a part is tested or not. Without testing, periodic process checks would be preformed to see that process parameters are within limits, such that tolerance limits are met in the final product. In this case you'd expect a small fraction of items to leak outside the tolerence limits. So the curve might be more or less a normal distribution. With 100% testing, those that exceed spec would be kicked out. In this case the distribution would be normal, with the tails of the curve truncated.
It also depends on the quality of the people. I've worked for some crap companies, whos specs were bogus.
But this is a lot of semi-educated guess-work on my part. Wish I knew better.
Register to reply
Related Discussions
Question about electrical components Introductory Physics Homework 0
percent hydrolysis/percent ionazation Biology, Chemistry & Other Homework 1
Anybody know about electrical components? Electrical Engineering 2
Perche i nostri discorsi---Galileo quoted by Rovelli Beyond the Standard Model 46
question about electrical components General Engineering 9
