Complex Analysis Proof showing that a Polynomial is linear
The problem involves a polynomial P(z) with the property that P(z) is real if and only if z is real. The goal is to prove that P is linear. The discussion revolves around the implications of this property and the use of the Cauchy-Riemann equations.
  • Participants discuss the implications of the polynomial being real only for real inputs and explore the consequences of the Cauchy-Riemann equations. There are attempts to connect the conditions given in the problem to the linearity of the polynomial, with some questioning the validity of certain assumptions.
Some participants are exploring different approaches to the proof, including the relationship between the polynomial's degree and its roots. Others express uncertainty about how the provided hints lead to the conclusion that P(z) must be linear, indicating a lack of consensus on the path forward.
There is mention of constraints related to the degree of the polynomial and the nature of its roots, as well as the application of the Fundamental Theorem of Algebra. Participants are also considering the implications of the polynomial having real coefficients.
QuantumLuck
Suppose P is a polynomial such that P(z) is real iff. z is real. Prove that P is linear.
The hint given in the text is to set P = u + iv, z = x+iy and note that v = 0 iff y = 0.
We are then told to conclude that
a. either v-sub y(partial of v with respect to y) is greater than or equal to 0 throughout the real axis or is less than or equal to 0 throughout the real axis;
b. either u-sub x(partial of u with respect to x) is greater than or equal to zero or is less than or equal to zero for all real values and hence u is monotonic along the real-axis;
c. P(z) = alpha has only one solution for real-valued alpha.
Cauchy-Reimann equations.
Fundamental Theorem of Algebra (FTA) (i think)
My friend was of the opinion that we can say v > 0 for y > 0, then we must have v < 0 for y < 0 because the FTA says v greater than or equal to 0 for all z is impossible. (yet i do not see how this follows at all and i am not sure the path to a solution that this will bring.
I am not quite sure how the proof is supposed to follow from the given guidelines and any help would be much appreciated (even a hint).
anyone have any ideas? after thinking some more i realize that b will follow from cauchy reimann equations so long as i have a. but, i fail to see how a, b, and c together define the polynomial P(z) to be linear or how part a is true.
Hmmm... I'm not sure off the top of my head, but notice P(z) being real when z is real isn't a very enlightening statement, as any real polynomial satisfies this. So the meat of the proof must lie in P(z) being real only when z is real
It's really not clear to me how to prove your hint a). But here's another approach. First show P(z) is a polynomial in z with real coefficients. Now from your knowledge of real polynomials, there is a real number A such that P(x)=A has either one or zero REAL roots (depending on whether the highest power of x is odd or even. That means if it's degree is greater than one, it must have a complex root r. Hence?
Thanks a lot Dick I was able to put together what you said with some of my professor's help to solve the problem. he didn't like the books method either. so i had to show that the power of the polynomial couldn't be even or an odd number that is three or greater. hence, it must be one.
  • · Replies 27 ·
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 19 ·
