Register to reply
Power and acceleration
by nolaman
Tags: acceleration, power
Share this thread:
nolaman
#1
Feb11-09, 04:31 PM
P: 12
This is a very old topic that I wanted to "publicize". My contention is that you cannot use power to calculate acceleration without first converting power to force. It is possible to calculate an acceleration by assuming some period of time to calculate a change in energy, but this method does not yield instantaneous acceleration. It seems trivial, but take a look at this spreadsheet.
http://spreadsheets.google.com/ccc?k...rplHUNFgrkT7HA
I've seen many, many equations that claim to do this calculation, but not one of them worked, and the ones that worked had the conversion from power to force buried in constants. So before posting any formulas please try them out with the spreadsheet to make sure they work.
Phys.Org News Partner Physics news on Phys.org
Physicists unlock nature of high-temperature superconductivity
Serial time-encoded amplified microscopy for ultrafast imaging based on multi-wavelength laser
Measuring the smallest magnets: Physicists measured magnetic interactions between single electrons
russ_watters
#2
Feb11-09, 04:56 PM
Mentor
P: 22,239
You are correct: acceleration is a function of torque at the wheels, so you need engine rpm and gear ratio (or a horsepower and a wheel rpm). Or, put another way, acceleration of a car is a function of the engine horsepower and what gear the car is, not engine horsepower alone.
So how is this useful? If you want more acceleration, stay in lower gears longer.
rcgldr
#3
Feb11-09, 05:20 PM
HW Helper
P: 7,034
You also need to know the mass of the vehicle being accelerated.
The last graph on that link shows an idealized case with a CVT (continously variable transmission); power output is constant, torque diminishes as speed increases. Here the inputs would be power and mass of vehicle. (The force at each instant = power / speed).
nolaman
#4
Feb11-09, 07:40 PM
P: 12
In fact, knowing the rear wheel horsepower and the gear does not yield a workable solution. As is pointed out in the spreadsheet, at a given engine horsepower the rear wheel horsepower is identically the engine horsepower in all six gears.
Useful, nope. But it is interesting. The formula that takes you from torque to HP must be backed out, that is, you must convert from power back to force to do any acceleration equations. It's a one-way, dead end street.
The weight data is in the spreadsheet.
rcgldr
#5
Feb11-09, 10:50 PM
HW Helper
P: 7,034
Quote Quote by nolaman View Post
But knowing the rear wheel horsepower and speed does work, since power = force x speed, then force = power / speed.
Cyrus
#6
Feb11-09, 11:51 PM
Cyrus's Avatar
P: 4,780
Could you provide these 'many many equations that claim to do this calculation?
nolaman
#7
Feb12-09, 01:42 PM
P: 12
Cyrus, they all fall apart. Most commonly the conversion from power back to force is imbedded in them, so they fail by definition. The others, most commonly based on energy change, do work after a fashion, but the results are ambiguous: The same amount of energy changenproduces different acceleration rates depending on initial (or final) velocity.
Jeff, that's converting back to force. That was a restriction in my original statement.
Cyrus
#8
Feb12-09, 05:20 PM
Cyrus's Avatar
P: 4,780
What is 'they'? Can you please provide said equations. I still don't know what you're talking about.
rcgldr
#9
Feb12-09, 07:04 PM
HW Helper
P: 7,034
Quote Quote by Jeff Reid View Post
That's converting back to force.
It's part of the definition of power, a rate of work, which equals force times speed.
For example, 1 horsepower = 550 ft lbf / sec = 550 lbf (ft/sec) = force x speed.
So there is an equation relating these three variables, power, force, and speed. If you know any two of these, you can calculate the third.
nolaman
#10
Feb13-09, 01:12 PM
P: 12
The original question is, knowing power in that example can you calculate acceleration without first converting back to force? The answer is no.
You need the total reduction of the driveline (including the drive wheel radius) and the RPM. Fair enough, you need that to calculate acceleration from torque. So now you have enough information to calculate acceleration using force. But you still don't have enough information calculate acceleration from power.
So with RPM, gear reduction, drive wheel radius (those three used only to calculate initial speed), mass, power and initial speed can you calculate acceleration? Once you've got all the details worked out and know the acceleration, what happens when the RPM changes?
It's like the old joke about a fellow who asks a farmer for directions. The farmer replies, "You can't get there from here. You've got to go someplace else first".
I will admit that my original statement is flawed in that you could say that power and acceleration are indirectly related. I must confess that was on purpose.
Cyrus, I didn't collect them. They didn't work so I had no reason to.
The Dagda
#11
Feb13-09, 01:20 PM
P: 266
This may sound flippant but what if your car has no wheels?
nolaman
#12
Feb13-09, 01:55 PM
P: 12
We're now in Zen-land, and the answer is that the car has nowhere to go.
The Dagda
#13
Feb13-09, 03:05 PM
P: 266
But if a car loses its wheels to a scouser and ends up on bricks does it still have horsepower and further is it moving? Ahhhhh....
Apologies to scousers but well you know.
I genuinely didn't mean it to be flippant, but I think in principle I agree with the OP, there is a certain removal from the subject.
Cyrus
#14
Feb13-09, 05:31 PM
Cyrus's Avatar
P: 4,780
I have no idea what you're talking about. I took a course in Vehicle Dynamics a year ago.
Why don't you just buy a book on vehicle dynamics and use it, why is what you are trying to do so hard?
You can't even provide any equations when asked.......
I think the problem is you're trying to plug and chug and have no idea about the scope of the use of your equations.
Garbage in = Garbage out
nolaman
#15
Feb13-09, 08:43 PM
P: 12
So I should have collected a bunch of half-baked and incorrect formulas?!
It's a simple question. Let me restate it this way: In the example in the spreadsheet, can a single, consistent formula be written that calculates acceleration from power without converting power to force? If not, then power is not mathematically related to acceleration.
This all goes back to an old discussion among gearheads: What's important in vehicle performance, torque or power? There's a split camp, one saying torque, the other power. One of my points is that when you look at the torque curve you are looking at the shape of the acceleration curve. The relationship between the torque curve and the actual acceleration curve is a single scaling number for each gear, consistent across the RPM range.
Looking at the power curve very few people could guess where the acceleration is higher, lower or static. And even then it takes a very educated guess.
This being a physics forum I thought maybe I'd pose the problem here. I don't mean to upset anyone. BTW, I'm a retired M.E., rotating equipment specialist.
vanesch
#16
Feb14-09, 12:08 AM
Emeritus
Sci Advisor
PF Gold
P: 6,236
Jeff Reid answered your question. You are correct that (assuming no dissipative losses) power alone doesn't give you acceleration: you need momentum too.
P = F x v
F = m x a
From that you find a = F / m = (P/v) / m = P / (m x v)
In other words, power divided by momentum gives you the acceleration.
And it doesn't matter how it is applied, through what gear ratio or whatever, and what's the diameter of the wheel.
Gear ratio serves simply to allow an engine with a given rpm/torque curve to allow to put out its maximum power at the given velocity. If you KNOW that your engine is delivering a certain amount of power, then you do not need to know the gear ratio.
nolaman
#17
Feb14-09, 08:47 AM
P: 12
That formula contains the conversion back to force (and requires calculating the velocity to find momentum). Momentum / velocity = force.
So far I haven't seen a formula that fills the criteria, and I've been looking a long time.
Thanks for the reply.
vanesch
#18
Feb16-09, 07:03 AM
Emeritus
Sci Advisor
PF Gold
P: 6,236
Yes, but you should understand that you do not need specific gearing ratios or whatever. Also, you do not need to know velocity to have momentum (although usually this is the way one calculates momentum). If mass is unknown, but momentum is known, that's good enough.
You can look forever, you won't find it because it doesn't exist. From power alone, you cannot calculate the acceleration, simply because for the same power, you can have different accelerations if your system under study has different momenta.
This is a bit like asking for the formula that gives you the two elements of a division, if you know the result (if you know that the result is 5, then you want to find: 35 and 7, because 35 divided by 7 equals 5) and you look all over the place for it. You won't find such a formula, simply because *different answers yield the same given*. In the same way, if you have 100 W of power, this can lead to an acceleration of 10 m/s^2 or of 0.1 m/s^2, depending on whether the momentum was 10 kg m/s or was 1000 kg m/s.
Register to reply
Related Discussions
Power and Acceleration Classical Physics 7
Power from Acceleration Introductory Physics Homework 2
4 homework problems (static coefficient, acceleration/direction, power, ect) Introductory Physics Homework 1
How is power proportional to acceleration? Introductory Physics Homework 5
Acceleration using Power... Classical Physics 5
