| Thread Closed |
Wichita UFO |
Share Thread | Thread Tools |
| Apr13-09, 07:42 PM | #69 |
Wichita UFOA) The object could be in the distance, greater than S1. I mentioned this possibility (that it is further away from the tree) only in order to disprove and rule out that possibility. If it were true, the con-trails in the far distant background show us the asymptotic limit of the radius of confusion on the far end, which is lower than the radius of confusion of the object. If the blurring is due to being out of focus, then this proves that the object is closer than the tree...and that's just based on the mathematics of it... B) A fast moving distant object that is motion-blurred? There are a number of reasons why this explanation is not realistic. First, even a fast moving distant plane is not likely to cause motion blur because it's apparent speed on the image plane is divided by distance. If the shutter were open long enough to cause motion blur, the tree would likely have even more motion blur due to being shot from a hand-held camera. Second, the blurring on the tail is isotropic, indicating that it is due to being out of focus rather than motion blur. C) The object could be in the foreground. This coincides with all visual evidence. There does appear to be some motion blur, and this is in support of it being closer, because a bird in the foreground is going to have dramatically more apparent movement in the image plane due to being so much closer (and having fast flapping wings). On top of all this, if it were a distant UFO, just look at how big it would have to be...a lot bigger than any plane by my reckoning. |
| Apr13-09, 07:53 PM | #70 |
It could be a kite (or glider) of some kind. If were seeing the belly of it from it's right side the little thing going down in front could be where the string attaches, and the string would be very hard to see with that much blurring. What you're saying about focus length does make sense, so that's why I ask. I could also see that easily being some kind of kite if you imagine it that way. At that angle the wings would be just about parellel to the ground and everything. Just an idea. I really have no idea.
| Apr13-09, 08:18 PM | #71 |
You have not demonstrated how out-of-focus the contrails are, you are just taking it as a given. One of most likely sources of the blur is camera-movement. That would explain why everything in the picture has (more or less) the same amount of blur and why the blur has quite sharp edges (look at the branches of the trees). |
| Apr13-09, 09:11 PM | #72 |
| Apr13-09, 09:19 PM | #73 |
![]() (and now with altered levels just to show that the foreground object does indeed blur out to that amount) ![]() Indeed, this is the basis of my argument...the con-trail being effectively at infinity shows the maximum radius of blurring that is possible to occur for an object due to being farther away than S1. Therefore, since the foreground object has significantly more blurring than the contrail, it must be closer than S1 and closer than the tree. |
| Apr13-09, 09:34 PM | #74 |
You are putting far too much faith in your analysis of blurring.
| Apr13-09, 09:53 PM | #75 |
If you took a photograph of 2 balls that you knew were the same size, and you measured one of them to have a radius of 5 pixels and the other to have a radius of 100 pixels, you would take it as proof that the larger one is closer to the camera. That is the same level of confidence that can be drawn from the blurring in this image, the only difference is that we don't need to know how large the objects are to do the analysis. My measurements may be crude, but I am only using them to show relative depth changes. In this case, all I needed to show to prove my point was that one circle is not the same size as the other by a statistically significant amount. In this case it's about 4 or 5 times larger, and the number of pixels under the area are effectively the number of measurements that corroborate that determination. So why are you so reluctant to believe it? |
| Apr13-09, 10:06 PM | #76 |
Dark objects and light objects do not blur the same way (light and lack-of-light are not two sides of the same coin). |
| Apr13-09, 10:39 PM | #77 |
If anything, the con-trail having a softer edge in real life only strengthens my argument that the con-trail is more in-focus than the blob, because despite having a softer edge in real life, it still appears crisper in the image than the blob. As for being transparent...it may be translucent up close but from afar it appears opaque. The only relevance that this would have on the analysis is that if the contrast from the background is too subtle, it would not be possible to determine the extent of the object's blur radius. In this case, the edge is distinctly visible, so it's not relevant. |
| Thread Closed |
| Thread Tools | |
