Register to reply
Charge distribution on a conductor.
by integration
Tags: charge, conductor, distribution
Share this thread:
integration
#1
Feb11-09, 08:51 PM
P: 10
Here is a problem I made up, in order to try to understand electrostatics of conductors better. Suppose two large square parallel conducting plates, are in space. One has a charge of Q, and another has a charge of -q. They are put close together, from a separation of L, to a separation of l (l < L). (abs(Q) different of abs(q))
1. Describe both the inital charge distribution of both plates, and, the electric field between and on the outer sides of both plates, once equilibrium is reached.
2. After waiting, you "inject" an extra amount of charge m to the plate with inital charge -q. What happens to the charge distribution? and to the electric field?
It would be really nice if you guys could provide explanations for your answers, as I am still trying to understand electrostatics.
2. Relevant equations
Gauss law, Coulomb's law, E=kq/R2
3. The attempt at a solution
My idea of solving this is setting E=0 inside the conductor. Considering charges can only be on the surface, I set up surface charge densities so that the E field contribution of both plates end up cancelling each other within each plates. My difficulty lies in the fact that how do I know if my distribution is unique? And also, how do I find the possible polarization of the plates due to the other plate?
Thanks so much.
Phys.Org News Partner Science news on Phys.org
Suddenly, the sun is eerily quiet: Where did the sunspots go?
'Moral victories' might spare you from losing again
Mammoth and mastodon behavior was less roam, more stay at home
Register to reply
Related Discussions
Charge Distribution on Conductor Classical Physics 9
Surface charge induced in conductor by point charge Introductory Physics Homework 17
Charge distribution on a conductor Classical Physics 10
The work required for adding a charge to an infinite charge distribution Advanced Physics Homework 1
Using Gauss (Divergence) theorem to find charge distribution on a conductor Advanced Physics Homework 3
