I think it's a conservation of energy problem
by Seraph404
Tags: conservation, energy
Seraph404
Seraph404 is offline
#1
Feb15-09, 03:06 PM
P: 64
An alpha particle with kinetic energy 10.5 MeV makes a collision with lead nucleus, but it is not "aimed" at the center of the lead nucleus, and has an initial nonzero angular momentum (with respect to the stationary lead nucleus) of magnitude L = p_0 b, where p_0 is the magnitude of the initial momentum of the alpha particle and b=1.0010−12 m. (Assume that the lead nucleus remains stationary and that it may be treated as a point charge. The atomic number of lead is 82. The alpha particle is a helium nucleus, with atomic number 2.)
a) find the distance of closest approach
2. Relevant equations
conservation of momentum and energy, I guess; formula for electric potential energy
3. The attempt at a solution
[Edit] Scroll to last post to see my attempt
I definately need some hints on this one. I don't think we've said anything about angular moment of particles during the physics course I'm in. I did a google search to refresh my memory on angular moment, and I recall that it's basically rotation.
Well, in this problem, I can't figure what's rotating around what. Or how this brings on a collision. I appreciate any help. However, I have solved a problem kind of like this that involved conservation of linear momentum and energy to find the closest distance two particles of the same charge got before jutting off in the opposite directions due to their opposing force on one another. But how can I apply the concept of angular momentum?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
tiny-tim
tiny-tim is offline
#2
Feb15-09, 03:49 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
Quote Quote by Seraph404 View Post
Hi Seraph404!
Nothing's rotating
any moving object has angular momentum about any point not on its line of travel
and its angular momentum is conserved
angular momentum = speed times perpendicular distance.
Seraph404
#3
Feb15-09, 05:36 PM
P: 64
Wait... does the alpha particle cause the lead nucleus to rotate?
tiny-tim
tiny-tim is offline
#4
Feb15-09, 05:38 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
You can assume not
Seraph404
#5
Feb15-09, 05:40 PM
P: 64
So then it's just approaching at an angle then? That's the only difference between this and what I described?
tiny-tim
tiny-tim is offline
#6
Feb15-09, 05:53 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
They're both charged, so the path will curve, but at closest approach, it will be moving perpendicular to the line joining them, which is all you need to know about the path.
Seraph404
#7
Feb15-09, 07:50 PM
P: 64
So far is this the correct setup?
L1 = L2
P0b = p(Rmin) [Rmin is the minimum distance the two particles get to each other]
v0b=vf(Rmin) [mass doesn't change so I canceled it]
K0+U0 = Kf+Uf
K0 = .5mV0^2 = 1 mil(1.602E-19) J [ I can use this to find initial velocity, assuming that I can use atomic mass given from the periodic table and divide it by avogadro's number to find the mass of a single atom (one source on the Internet said I could ignore the mass of the electrons - that all the mass is really contained in the nucleus)]
U0 = kq1q2/b [would the charge on on the alpha particle be the atomic # times the charge of one proton? and similar for the second particle?]
Kf = .5mVf^2 [ I think I can change my expression for angular momentum and substitute in for this Vf so that I only have one unknown variable]
Uf = kq1q2/ Rmin
Then I think I can plug in "v0b/Rmin" for Vf. And then I get my terms containing Rmin on one side and everything else on the other. The plug in numbers and take the reciprocal of each term on each side of the equation so that I have a quadratic allowing me to solve for Rmin.
Will this work? I'm working on it now to see, but if this set up is wrong, it sure would save a lot of time to know beforehand.
[Edit] Well, I tried it and I ended up with a negative distance of much greater magnitude than what I started out with. So now that I've expended my best guess, any other ideas on how to approach this problem?
tiny-tim
tiny-tim is offline
#8
Feb16-09, 02:39 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
Just got up …
Everything looks ok , except …
U0 = kq1q2/b
where does 1 mil(1.602E-19) come from?
and U0 = 0 (you can take it that the alpha particle starts so far away that it's effectively at infinity … the physical significance of b is only that it's the distance by which it would miss the nucleus if there was no repulsion).
Seraph404
#9
Feb16-09, 01:40 PM
P: 64
I looked up on google what MeV stood for and I saw that it was 1 electron volt times a million. Maybe my source was wrong *shrug*.
So is b significant at all in finding the closest distance that the alpha particle comes to the lead nucleus?
tiny-tim
tiny-tim is offline
#10
Feb16-09, 01:44 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
b is essential to the angular momentum equation, but you can ignore it for the energy equation.
Register to reply
Related Discussions
Conservation of Energy Problem Introductory Physics Homework 1
Potential energy and energy conservation problem Calculus & Beyond Homework 9
Conservation of Energy Problem Introductory Physics Homework 5
conservation of energy problem Introductory Physics Homework 1
Potential Energy, Conservation of Energy problem Introductory Physics Homework 3
