Infinite sheets of charge w/ conducting slab
The discussion centers on calculating the surface charge density on each side of an infinite conducting slab placed between two infinite sheets with surface charge densities σ1 = 8.85 μC/m² and σ2 = 1.5 μC/m², and a net charge per unit area of σC = -3 μC/m². The conducting slab has a thickness of a = 2 cm. The user successfully calculated the x-component of the net electric field at x = 0 but seeks assistance in determining the surface charge densities on either side of the slab, confirming that these must equal the total surface charge density of the slab.
  • Understanding of electric fields and surface charge density
  • Familiarity with Gauss's Law and its applications
  • Knowledge of electrostatics, particularly in relation to conductors
  • Basic calculus for solving electric field equations
  • Study the application of Gauss's Law in electrostatics
  • Learn how to calculate electric fields due to surface charge densities
  • Explore the concept of electric field discontinuity at the surface of conductors
  • Review problems involving multiple charged plates and their interactions
Students preparing for exams in electrostatics, physics educators, and anyone studying electric fields in the context of conductors and charge distributions.
rgalvan2
Two infinite sheets with surface charge density σ1 and σ2, respectively, are oriented perpendicular to the x-axis. An infinite, conducting slab of thickness a is placed between the charged sheets as shown in the figure. The conducting plate has a net charge per unit area of σC.
σ1=8.85[tex]\mu[/tex]C/m^2
σ2=1.5[tex]\mu[/tex]C/m^2
σC=-3[tex]\mu[/tex]C/m^2
a=2cm
E=[tex]\sigma[/tex]/2[tex]\epsilon[/tex]0
I figured since the magnitude of the electric field is not determined by displacement, I could just use the above equation. The only problem it that the conducting slab has different surface charge density on each side and I'm not sure how to start this. I have an exam tomorrow so any help is greatly appreciated!
What are you asked to find?
Oops sorry:
Calculate the x-component of the net electric field at x = 0.
I figured that part out though.
The next part asks to calculate the surface charge density on each side of the slab. I'm not sure how to do that. I do know that both sides need to equal the total surface charge density of the slab. Is that right?
  • · Replies 26 ·
  • · Replies 17 ·
14K
21K
