Solve Octet/Duet Rule Equation: NOCl?? | Answer
  • Thread starter Thread starter hockeyfghts5
The discussion focuses on solving the equation for the compound NOCl?? by applying the octet and duet rules. Participants emphasize the importance of drawing a Lewis dot structure to visualize electron sharing and determine oxidation states. The key conclusion is that balancing the total negative charge with positive charge is essential for finding the correct subscript. The missing subscript for NOCl is determined through these methods.
  • Understanding of the octet rule and duet rule in chemistry
  • Familiarity with Lewis dot structures
  • Knowledge of oxidation states and charge balancing
  • Basic principles of chemical bonding
  • Study how to draw Lewis dot structures for various compounds
  • Learn about oxidation states and their significance in chemical reactions
  • Research the octet rule and its exceptions in more complex molecules
  • Explore charge balancing techniques in ionic and covalent compounds
Chemistry students, educators, and anyone interested in understanding molecular structure and bonding principles.
hockeyfghts5
Using your knowledge of the octet rule and the duet rule, determine the missing subscript (??) for the compound below.
NOCl??
What is a good way of solving this type of equation and what is the answer. I figure you need to draw a Lewis dot structure but knowing what else is need i don't know.
NOCl??
...I figure you need to draw a Lewis dot structure...
Yes, try that. You should be able to determine a reasonable oxidation number. Once you have that, balance the total negative charge with positive.
