Thread Closed
How to calculate section modulus of channel section
Share Thread Thread Tools
Feb18-09, 10:15 AM   #1
Hi guys,
I am trying to calculate the section modulus of some channel section. I was going to use the value provided on the data sheet but its confusing me because it has values of section modulus in the X and Y axis. Am i right in assuming that i use section mod value where the load is perpendicular to its axis?
Also how would you calculate this value from scratch. Im familiar with calculating the section modulus of a sections that are symetrical in two axis, but not with those in one.
Any help would be much appreciated.
Cheers,
Amir
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb22-09, 08:11 PM   #2
You are doing bending calculations right?
Yes you would be interested in the section modulus of the axis perpendicular to the load.
Also the section modulus of the top and bottom of the channel (on the same axis) will be different if the cross-section isnt symmetrical about that axis (the neutral axis wont be in the center of the cross section). If you are putting a load on the top and creating bending moments, then you would use the bottom section modulus to check tension and the top section modulus to check compression stresses.
Theres some info there (though its a bit short) explaining it:
http://en.wikipedia.org/wiki/Section_modulus
Feb23-09, 06:33 AM   #3
Thanks very much for the clarification elterrible, much appreciated.
Yes its for a bending moment, i havent really worked with beams that are symetrical in one plane only so was a bit unsure. Thanks for your help,
Cheers
Amir
Thread Closed
Thread Tools
Similar Threads for: How to calculate section modulus of channel section
Thread Forum Replies
Section Modulus, major & minor axis Engineering, Comp Sci, & Technology Homework 6
Moment of Inertia / Section Modulus for a cruciform (rectangular cross) Engineering, Comp Sci, & Technology Homework 3
Bug Possible bug in HW section Forum Feedback & Announcements 1
Open Channel Flow (mannings equation) rectangular section Engineering, Comp Sci, & Technology Homework 1
Art Section Please Forum Feedback & Announcements 12
