Conservation of Linear Momentum
by peaceandlove
Tags: conservation, linear, momentum
peaceandlove
peaceandlove is offline
#1
Feb19-09, 10:52 PM
P: 70
An object, with mass 71 kg and speed 23 m/s relative to an observer, explodes into two pieces, one 5 times as massive as the other; the explosion takes place in deep space. The less massive piece stops relative to the observer. How much kinetic energy is added to the system during the explosion, as measured in the observer's reference frame?
2. Relevant equations
Equation 1: m1=5m2
Equation 2: (1/2)mv^2
Equation 3: mv1 (intiial) + mv2 (initial) = mv1 (final) + mv2 (final)
3. The attempt at a solution
I used equation 1 go determine the masses of the two exploded pieces and determined the initial kinetic energy by plugging in 71 kg and 23 m/s into equation 2. I then plugged in all the data into equation 3, where mv2 (final) is equal to 0, and solved for mv1 (final). I then plugged the final velocity for object 1, as well as the mass, into equation 2. When I subtracted the initial kinetic energy from the final kinetic energy, I came up with 93897.5 J.
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Delphi51
Delphi51 is offline
#2
Feb19-09, 11:54 PM
HW Helper
P: 3,394
Have to do conservation of momentum to find the speed of that heavier piece.
Only then can you calculate the KE after the explosion.
Oh, sorry, I guess that is just what you did! Did you get v = 27.6 for the bigger piece?
peaceandlove
#3
Feb20-09, 12:03 AM
P: 70
Oh! I think I know what I did wrong. For some reason I read that the LARGER piece stopped relative to the observer, but it's the SMALL piece that stops. In that case, wouldn't the answer be 3755.9 N? I got that by doing (1/2) times the mass of the larger piece times the final velocity of the larger piece. From that I subtracted (1/2) times the mass of the entire object before it exploded times the velocity of the entire object before it exploded.
Delphi51
Delphi51 is offline
#4
Feb20-09, 12:06 AM
HW Helper
P: 3,394
Yes, I got 3755!
Register to reply
Related Discussions
Conservation of Linear Momentum Introductory Physics Homework 1
Linear Conservation of Momentum Introductory Physics Homework 1
Conservation of linear momentum Introductory Physics Homework 12
conservation of linear momentum Introductory Physics Homework 3
