flow through parallel pipes with different diameters
by berkanozturk
Tags: fluid, laminar flow, parallel pipes
berkanozturk
berkanozturk is offline
#1
Feb20-09, 09:50 AM
P: 2
Consider an apparatus design in which two tubes of different diameters are connected in parallel to each other.
The flow is steady and fully developd in both tubes. Do your analysis regarding
a)the governing differential equations for the case that in both tubes laminar flows occur.
2. Relevant equations
Asked
3. The attempt at a solution
Hello everyone,
For one pipe, we can simply use Reynolds transport theorem for a differential volume, and then get the related conservation of mass and momentum equations for 1 PIPE. However, when there are two pipes, how should I relate it? I could not solve it, hope you can help me. thanks for reading so far...
best regards
berkan
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
Astronuc
Astronuc is offline
#2
Feb22-09, 05:13 PM
Admin
Astronuc's Avatar
P: 21,637
Assuming the pipes are connected to the same manifolds (headers), then the pressure drops across the pipes (lengthwise) would be the same. The flow rates would be different because the flow resistance would be different (including the cross-sectional areas).
The electrical analog is two resistors in parallel. Both resistors have the same potential drop across their terminals, but the current (charge flow rate) is different.
orkun
orkun is offline
#3
May11-10, 02:09 AM
P: 1
using bernoullli equation;
P/p + 1/2(V)^2=constant, (P:pressure, p:density, V:velocity)
lets say pipe1 is carrying the main stream and pipe2 and pipe3 are the parallel pipes with different diameters,
then it must be;
P1/p + 1/2(V1)^2 = P2/p + 1/2(V2)^2 = P3/p + 1/2(V3)^2
Remember;
Q=A*V
for different diameters crossectional area difference also changes V (as i know, correct me if i m wrong), so;
P2=P3 can not be achieved.
when it comes to may be
P1=P2 or P1=P3 ?
it depends on V1, V2 and V3 again. the same V will result the same P if material properties (heat, density etc.) and level of pipes not changed.
Register to reply
Related Discussions
Flow through a semi circular pipes Classical Physics 0
Water flow in pipes Engineering, Comp Sci, & Technology Homework 0
[SOLVED] Water flow in pipes Introductory Physics Homework 5
how pipes in parralel works in comparison to pipes in series Classical Physics 3
More on flow through pipes Mechanical Engineering 1
