| Thread Closed |
Christoffel symbols |
Share Thread | Thread Tools |
| Feb21-09, 01:24 PM | #1 |
Christoffel symbols
Hi all!
I read about tensor analysis and came about following expressions, where also a questions arose which I cannot explain to me. Perhaps you could help me: I: Consider the following expressions: [tex]d\vec v=dc^k e^{(k)}[/tex] [tex]d\vec v=dc^k e_{(k)}[/tex] where: [tex]dc^k=dv^k+v^t\Gamma_{wt}^k dx^w[/tex] [tex]dc_k=dv_k-v_t\Gamma_{wk}^t dx^w[/tex] Now, consider the covariant derivatives: [tex]\frac{\partial c^k}{\partial x^q}=\frac{\partial v^k}{\partial x^q}+v^t\Gamma_{wt}^k \frac{\partial x^w}{\partial x^q}=\frac{\partial v^k}{\partial x^q}+v^t\Gamma_{wt}^k \delta^w_q=\frac{\partial v^k}{\partial x^q}+v^t\Gamma_{qt}^k[/tex] analagous: (1)[tex]\frac{\partial c_k}{\partial x^q}=\frac{\partial v_k}{\partial x^q}-v_t\Gamma_{qk}^t [/tex] So far so good, here I start transforming: [tex]\frac{\partial c_k}{\partial x^q}=\frac{g_{kl}\partial c^l}{\partial x^q}=g_{kl}\frac{\partial c^l}{\partial x^q}=\frac{g_{kl}\partial v^l}{\partial x^q}+v^t\Gamma_{qt}^l g_{kl}=\frac{\partial v_l}{\partial x^q}+v^t\Gamma_{qtk}[/tex] As the second term looks different from the one above we continue transforming it: [tex]v^t\Gamma_{qtk}=v^t\Gamma_{qk}^s g_{ts}=(t\rightarrow s, g_{ts}=g_{st})=v^s\Gamma_{qk}^t g_{ts}=v_t\Gamma_{qk}^t[/tex] so, we finally get: (2)[tex]\frac{\partial c_k}{\partial x^q}=\frac{\partial v_k}{\partial x^q}+v_t\Gamma_{qk}^t[/tex] By comparing (1) and (2) I miss a minus sign! I suspect that the Christoffel symbol of first kind is antisymmetric and indices permute just like they do in the epsilon tensor and thereby generate a minus but I am not sure... II: In both of the above daces of derivatives one uses dx^q as differential which is contravariant. Does it make sence to also use a covariant dx_q? Is in general differentiation of covariant vectors with respect to a covariant variable defined? (I suppose it must be, since you also differentiate a contravariantvector w.r.t. a contravariant variable) III: And another question: Is the Kronecker delta symmetric in non-orthogonal coordinates [tex]\delta^i_j=\delta^j_i[/tex] ??? If not, then which one of the two definitions is correct: (Iīve seen both in the net) [tex]e^{i}e_j=\delta^j_i[/tex] or [tex]e^je_i=\delta^j_i[/tex] I have also seen two types in which you define covariant vectors: [tex]\vec v=v_ke^k[/tex] and [tex]\vec v=v_ke_k[/tex] Which one is correct, or do they just represent the same covariant vector once in the covariant and in the contravariant basis? IV: And the last one: I havenīt seen a classification of the Christoffel symbol of this kind: [tex]\Gamma^{kl}_m[/tex] Is it also symmetric in the upper indices? Thanks a lot, I really appreciate your help! marin |
| Feb21-09, 02:07 PM | #2 |
It is true that [itex]\Gamma^{qk}_t= -\Gamma{tk}_q[/itex] and that [itex]\Gamma^{qk}_t= \Gamma^{kq}_t[/itex]. [qote]II: In both of the above daces of derivatives one uses dx^q as differential which is contravariant. Does it make sence to also use a covariant dx_q? Is in general differentiation of covariant vectors with respect to a covariant variable defined? (I suppose it must be, since you also differentiate a contravariantvector w.r.t. a contravariant variable)[/quote] Yes, you can use covariant [itex]dx_q[/itex] if you also lower the indices on the Christoffel symbols. [itex]\Gamma_{ij, t}= g_{ki} g_{jq}\Gamma^{kq}_t[/itex]. |
| Feb21-09, 02:59 PM | #3 |
ok, now let me try and see:
[tex]\Gamma^l_{qt}=\Gamma^l_{tq}=-\Gamma^q_{lt}=-\Gamma^q_{tl}=\Gamma^t_{lq}[/tex] and also: [tex]\Gamma^l_{qt}=-\Gamma^t_{ql}=-\Gamma^t_{lq}[/tex] seems to me like a contradiction.. Can you please point out the wrong equalities, so that I get a better understanding? thanks |
| Feb21-09, 04:24 PM | #4 |
Christoffel symbolsI asked before what definition of the Krisstofel symbols you are using. The ones I am familiar with are [tex]\Gamma_{ij,k}= \frac{1}{2}\left(\frac{\partial g_ik}{\partial x^j}+ \frac{\partial g_{jk}}{\partial x^i}- \frac{\partial g_{ij}}{\partial x^k}\right)[/tex] [tex]\Gamma^{i}_{jk}= g^{im}\Gamma_{jk,m}[/tex] The symmetry rules follow from that. |
| Feb22-09, 01:33 AM | #5 |
I also "use" the definition you stated, but havenīt studied it thoroughly yet, perhaps I had to, before I try to take on expressions.
Anyway, Iīll go on trying to understand this stuff and some new and will pose some questions again. Thanks once again for the help! |
| Feb22-09, 07:50 AM | #6 |
ok, I tried the following transformation:
[tex]\Gamma^w_{bt}=\Gamma^w_{bt}\delta^b_b=\Gamma^w_{bt}\delta^b_w\delta^w_b =\Gamma^w_{bt}\delta^b_w\delta^b_w=(\Gamma^w_{bt}\delta^b_w)\delta^b_w= \Gamma^w_{wt}\delta^b_w=\Gamma^b_{wt}=\Gamma^b_{tw}[/tex] But this implies that nothing changes with the Christoffel symbol if I permute the indices evenly. But then, HallsofIvy, the equation you posted does not hold any more.. I suppose Iīve done something wrong again, so could someone please help me :) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Christoffel symbols
| Christoffel symbols | Special & General Relativity | 5 | ||
| Christoffel Symbols | Advanced Physics Homework | 12 | ||
| Christoffel Symbols | Advanced Physics Homework | 5 | ||
| Christoffel symbols from definition or Lagrangian | Calculus & Beyond Homework | 0 | ||
| christoffel symbols examples | Differential Geometry | 7 | ||
