Specific Impulse and Exhaust Velocity
The discussion revolves around the concepts of specific impulse and exhaust velocity in rocket engines, including the relevant formulas and their applications. Participants explore the relationships between thrust, mass flow rate, and acceleration, while also addressing the implications of combustion temperature and engine pressure.
  • Some participants seek clarification on the formulas for specific impulse and exhaust velocity, questioning how to calculate mass flow rate (Δm/Δt) and its relation to changes in mass and time.
  • There is a discussion about whether the change in velocity is defined as velocityfinal - velocityinitial, with some participants confirming this interpretation.
  • One participant suggests that specific impulse should be understood in terms of velocity rather than time, arguing that it reflects the efficiency of an engine.
  • Another participant mentions that the acceleration at Earth's surface (g0) is approximately 9.8 m/s², while others discuss its role in the context of thrust calculations.
  • Some participants express a desire for practical examples, such as applying the formulas to real rocket engines like the Space Shuttle main engine or solid rocket boosters.
  • There are references to external resources for further understanding of mass flow rate and pressure calculations.
  • One participant proposes that specific impulse is a measure of how efficiently an engine consumes fuel, comparing different types of rocket engines.
Participants generally express uncertainty about the application of the formulas and the interpretation of specific impulse. Multiple competing views exist regarding the best way to conceptualize specific impulse and its implications for engine efficiency.
Participants note limitations in their understanding of the formulas and the need for examples to clarify the concepts. There is also mention of unresolved mathematical steps related to pressure and thrust calculations.
This discussion may be useful for individuals interested in rocket propulsion, engineering students, or anyone looking to deepen their understanding of specific impulse and exhaust velocity in rocket engines.
.:Endeavour:.
I would like an explanation with this formulas for a rocket engine and any other engine to calculate its exhaust velocity and its specific impulse. I realized that this formulas neglect combustion temperature, engine pressure, speed of the fuel is injected, etc.
This is the formula that I found in http://www.answers.com/topic/specific-impulse for the specific impulse:
Fthrust = Isp * (Δm/Δt) * g0
-Fthrust = Force thrust in Newtons
-Isp = Specific Impulse in seconds
-(Δm/Δt) = is the mass flow rate in kg/s (lb/s), which is minus the time-rate of change of the vehicle's mass since propellant is being expelled.
-g0 = is the acceleration at the Earth's surface, in m/s² (or ft/s²).
This another variation to find the thrust of an object:
Fthrust = ve * (Δm/Δt)
This is the formula the exhaust velocity:
ve = g0 * Isp
I want to know know how do you find the change of mass and change of time in the the formulas, (Δm/Δt). Does this part of the formula translate as: (massf - massi)/(timef - timei)? And my last question is for g0 when it means acceleration at Earth's surface, is it 9m/s2 or is it 9m/s2 * something? I found more equations for an ideal rocket in NASA's page, http://www.grc.nasa.gov/WWW/K-12/rocket/rktpow.html. I would like to see some example using this formulas because you cannot really apply them if you don't know how they are applied. Thank you for your time. This is not a homework question.
Maybe an explantion of the force part would help.
Force = mass x acceleration
Force = mass x (change in velocity) / (unit time)
Force = mass / (unit time) x (change in velocity)
Force = mass flow rate x change in velocity
When you say the change in velocity, do you mean this: velocityfinal - velocityinitial? That's something that has been bugging me because I think that what it means, but I'm not sure because there isn't an example to see if its velocityfinal - velocityinitial.
.:Endeavour:. said:
When you say the change in velocity, do you mean this: velocityfinal - velocityinitial?.
Yes, the total change in velocity.
And Δm or change in mass is the same as the chane in velocity which is massf - massi? Also g0 the acceleration at Earth's surface is equal to 9.8m/s2? I want to make sure that I have these formulas first in check before I start to use them so I use them how they are suppose to be used.
Can you give an example of g0 as well as the mass flow rate because its still isn't quite clear to me. Would it be easier to understand if I apply it into a real time object, like a space shuttle main engine, SRB, F-1, J-2, etc.
I've read the information in the link that you send me, but I still need some clarification on mass flow rate along with the (Pe - P0) * Ae. To get the pressure for Pe and P0, you do Pressure = Force / Surface Area?
Take a look at this nozzle simulator - http://www.lerc.nasa.gov/WWW/K-12/airplane/ienzl.html
Pe is the pressure in the flow at the nozzle exit, and Po is the free stream pressure, which is essentially 0, vacuum, in space.
The use of go is arbitrary. IMO, it's an uncessary proportionality constant which converts mass to weight.
With respect to mass flowrate, see -
http://www.lerc.nasa.gov/WWW/K-12/airplane/thrsteq.html
http://www.lerc.nasa.gov/WWW/K-12/airplane/mflchk.html
It's just the amount of mass flowing across some reference cross-sectional area per unit time, e.g. 10 kg/s, and is also the measure of propellant consumption. One could measure it volumetrically, e.g. gallons per minute, pgm. Multiply the volumetric flowrate by density, one would get mass flow rate.
My advice: Forget about specific impulse as being in units of seconds. IMO, its much better to think of it as having units of velocity. For one thing, that is much more in line with the name. "Specific" means divided by mass (of the exhaust, in this case), "impulse" means change in momentum. Specific impulse should logically have units of momentum/mass, or velocity. In fact, this is exactly how many who use the metric system express specific impulse. That specific impulse is typically expressed in seconds in the US is essentially a reflection on the goofy system of measurements used in the US -- as Astronuc already said, thrust per weight flowrate.
A thruster with a specific impulse of 408 seconds used in orbit around the Pluto will have an effective exhaust velocity of about 4000 m/s. That effective exhaust velocity is very real. The 408 seconds is not.
Now I get what you mean about specific impulse which is to tell how efficiant an engine is. A rocket engine isn't efficiant because it burns more fuel than an airplane will to produce thrust to lift off the ground. So when you say that a thruster has a specific impulse of 408 seconds that means that its consuming fuel just like a liquid fuel rocket would be consuming. A solid rocket booster will have an even lower specific impulse because they burn their fuel at a faster rate than a liquid fuel rocket then. So, a Me 163B Komet 1 will have an approximate specific impulse of 400 seconds because its a bi-propellant rocket, similar to the OMS of the Space Shuttle where the 2 propellants mix to produce thrust? Thanks for the clarification of specific impulse, DH.
The URLs that you posted, Astronuc, I finally figured out how to calculate or the calculations of the mass flow rate that I found on the links and on my school notes as well. This is what I have for the mass flow rate:
[tex] F = \frac{\Delta\ p}{\Delta\ t}[/tex]
which is:
[tex] F = \frac{mV2-mV1}{t2-t1}[/tex]
So, is the mass flow rate given by that formula that I posted?
  • · Replies 47 ·
