What is the Vertical Force on the Support Closest to the Piano?
The vertical force on the support closest to the piano, when a 160 kg beam and a 300 kg piano are in equilibrium, is calculated to be 1960 N downward. This conclusion is derived from applying the principles of equilibrium, where the sum of vertical forces must equal zero. The total weight of the beam is 1568 N and the piano contributes an additional 392 N. By setting up the equation for total vertical forces, the negative value indicates the direction of the force acting on the support.
  • Understanding of static equilibrium principles
  • Knowledge of weight calculation using mass and gravitational acceleration
  • Familiarity with torque and force distribution
  • Basic physics concepts related to forces and moments
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations and their applications
  • Explore real-world applications of force distribution in structural engineering
  • Investigate similar problems involving multiple forces and supports
Students of physics, engineering professionals, and anyone interested in understanding force distribution in static systems will benefit from this discussion.
pupatel
A 160 kg horizontal beam is supported at each end. A 300 kg piano rests a quarter of the way from one end.
What is the vertical force on the support closest to the piano?
How do i do this? :confused:
conditions for equilibrium
Consider that for equilibrium:
(a) Net force must be zero
(b) Net torque about any point must be zero
To calculate the vertical force on the support closest to the piano, we need to use the principle of equilibrium in physics. This states that the sum of all forces acting on an object must be equal to zero in order for it to be in a state of equilibrium.
In this scenario, the beam is in equilibrium since it is not moving or rotating. This means that the total vertical forces acting on the beam must be equal to zero.
Let's start by calculating the total weight of the beam and piano combined. The weight of the beam can be calculated by multiplying its mass (160 kg) by the acceleration due to gravity (9.8 m/s^2), giving us a weight of 1568 N.
Next, we need to find the weight of the piano. Since it is resting a quarter of the way from one end, we can assume that the distance from the support closest to the piano to the piano itself is one quarter of the total length of the beam. This means that the weight of the piano would be one quarter of the weight of the beam, which is 392 N.
Now, we can set up an equation to find the vertical force on the support closest to the piano:
Total vertical forces = Weight of beam + Weight of piano + Vertical force on support closest to piano
Since the beam is in equilibrium, the total vertical forces must be equal to zero. We already know the weight of the beam (1568 N) and the weight of the piano (392 N), so we can plug those values into the equation:
0 = 1568 N + 392 N + Vertical force on support closest to piano
Solving for the vertical force on the support closest to the piano, we get:
Vertical force on support closest to piano = -1960 N
This means that the vertical force on the support closest to the piano is 1960 N in the downward direction. This is due to the weight of the beam and piano pulling down on the support.
In summary, using the principle of equilibrium, we can calculate the vertical force on the support closest to the piano by considering the weight of the beam and piano and setting them equal to the total vertical forces acting on the beam. This helps us understand the distribution of forces in a vertical force scenario and can be applied to other similar problems.
  • · Replies 98 ·
  • · Replies 18 ·
