Solve ODE for Free Fall with Drag: Find v(t)
The problem involves solving a differential equation that models the velocity of a skydiver in free fall, accounting for drag. The equation presented is dv/dt = -9.8 + 0.0045Av^2, with an initial condition of v(0) = 0.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to solve the ODE using separation of variables and integration, but encounters issues with the initial conditions leading to division by zero. Some participants suggest re-evaluating the setup of the differential equation, particularly regarding the direction of the drag force and the sign conventions used.
Participants are actively discussing the setup of the differential equation and the implications of the initial conditions. Some guidance has been offered regarding the correct form of the solution and the use of hyperbolic functions, but no consensus has been reached on the best approach to resolve the issues identified.
There are indications of confusion regarding the signs in the differential equation and the treatment of initial conditions. The original poster also expresses a desire to express the solution in terms of hyperbolic tangent for ease of further calculations.
tua96426
Need to solve the differential equation which models the velocity of a sky diver.
dv/dt = -9.8 + 0.0045Av^2 where A is cross sectional area (assume 0.75m^2)
v(0) = 0
ok the problem is to find v(t) as a function time. as they teach us any ODE class, I started with separation of vars and on the left i had (dv/0.0045Av^2 - 9.8) and dt on the right,
then integrate both sides. The right hand side just becomes t + y (constant of integration) and the left needs to be simplified first with partial fractions
I said let c =sqrt(0.0045A) and b= sqrt (9.8)
then we have dv/(cv)^2 - b^2 which is now a difference of perfect squares ..
so partial fractions: A/(cv - b) + B(cv+b)
getting common denominator we get Acv + Ab + Bcv - Bb = 1
so all vars together: Ac + Bc = 0 >>> A+B = 0 therefore A = -B
then looking at the constant terms, I get b(A-B) = 1 >>> A = 1/b + B
so equation the two equations for A we get B = -1/2b and A = 1/2b
B = -1.565 and A = 1.565
so now we have Integral of (1.565/cv-b) + (-1.565/cv-b) dv
making a u substitution: u = cv +/- b >> du = cdv >>> dv = du/c
so we have (-1.565/c)ln|cv-b|+ (-1.565.c)ln|cv+b| = t + y
taking 1.565/c common on the left and multiplying by c/1.565 on both sides.. and getting all ln into one, I got
ln |(cv-b)/(cv+b)| = (c/1.565)(t+y)
let x = -c/1565
so doing more of mumbo jumbo, i get
v(t) = (b/c) ((1 + e^x(t+y))/(1-e^x(t+y)))
some how after applying the initial conditions, I got y = 0, but when I plug in 0 for t after getting the unique soln for v(t), I do not get 0 for velocity; rather I end up dividing by 0..
I researched this on wiki and they have the answer in tanh, which my prof said is possible. I was wondering how to get it in that form.. infact if I am able to express it in tanh it becomes easier for me to do the following problems (need to integrate and so on and so forth) .. any help on this would be gr8 peeps!
thanks
- Sudhi
i think it could be the way you set up the DE
the drag force should oppose velocity. As you're working with v^2 will need to define poitsive velocity downwards
so try
v' = g - cAv^2
Hi Sudhi, welcome to PF!:smile:
You seem to have made a slight error in your "mumbo jumbo" steps; you should be getting [tex]v(t)=\frac{b}{c}\left(\frac{1-e^{x(t+y)}}{1+e^{x(t+y)}}\right)[/tex]
Also, you could have very easily determined y just by plugging in t=0 and v=0 into ln |(cv-b)/(cv+b)| = (c/1.565)(t+y).
Use the definition of hyperbolic tangent:
[tex]\tanh(u)=\frac{e^u-e^{-u}}{e^u+e^{-u}}=\frac{1-e^{-2u}}{1+e^{-2u}}[/tex]
so try
v' = g - cAv^2
The DE is fine, it assumes downwards corresponds to a negative v(t), and so the acceleration due to gravity is indeed downwards (-9.81) while the drag force is upwards (+.0045Av^2).
woops - my bad, sorry to send you on the wrong track
and as; for mumbo jumbo, i think you mix up a few negative signs early on
will make life easier as well if you write -t (ie put a negative on the t side) before combining the ln's or taking the exponentials - this is currently hidden in your x... i find its usually easiest to make constants positive as a convention
this will give you the equation starght away with something like a.(1-e^(-kt)) in the numerator so velocity starts at zero, accelerates quickly then heads towards a limiting velocity as the drag forces kick in
  • · Replies 20 ·
  • · Replies 0 ·
