Register to reply
Constant Volume Thermometer
by orthovector
Tags: constant, thermometer, volume
Share this thread:
orthovector
#1
Feb28-09, 09:18 PM
P: 115
Does anybody know how a Constant volume thermometer works?
I know that one of the reference points is the triple point of water, but I'm not sure how different gases are used along with this reference point to get different values of temperature for certain known processes. for instance, if oxygen gas is used to measure the BP of water....one gets a certain temperature that is close to 373.15 degrees kelvin. if nitrogen gas is used, one gets a value that is also close to 373.15 degrees kelvin...but it is different from the value from using oxygen gas.
I cannot picture what is going on....
Phys.Org News Partner Physics news on Phys.org
Mapping the optimal route between two quantum states
Spin-based electronics: New material successfully tested
Verifying the future of quantum computing
mgb_phys
#2
Mar1-09, 11:27 AM
Sci Advisor
HW Helper
P: 8,954
It uses a constant volume of gas and measures the pressure so from PV=nRT you get the temperature. But the equation assumes a perfect gas so for a real gas you will get a small error because of a, the molecules of oxygen occupy real space so at 0K there is still a volume and b, there is an interaction between molecules so there is more pressure than you would expect.
orthovector
#3
Mar1-09, 11:43 AM
P: 115
I know that.... I just can't imagine how you would measure a process. For instance, if you want to measure the bp of water, do you place the gas bulb into the water and hear the water??? And how would u take a reading of the pressure?
mgb_phys
#4
Mar1-09, 12:07 PM
Sci Advisor
HW Helper
P: 8,954
Yes - you put the bulb in the boiling water (or ideally in the vapour just above it)
Then you measure the pressure with a separate pressure gauge attached to the bulb - normally a mercury manometer but probably with some sort of digital pressure guage nowadays. I must admit I've only seen 'lab demonstration' type constant volume gas thermometers, not a real industrial one.
jtbell
#5
Mar1-09, 12:15 PM
Mentor
jtbell's Avatar
P: 11,626
You can find links to lab experiments that use a constant volume gas thermometer here:
http://www.google.com/search?q=const...as+thermometer
orthovector
#6
Mar1-09, 12:17 PM
P: 115
how would one measure the triple point of water? as u know, triple point occurs ar specific pressure and temp.
Dadface
#7
Mar1-09, 02:00 PM
PF Gold
Dadface's Avatar
P: 2,011
You use something called a triple point cell.This is evacuated and pure water added but the cell is not filled up., It is then left in the fridge so that some of the water freezes,you now have the triple point with ice water and water vapour in equilibrium.
Register to reply
Related Discussions
Constant Volume and Constant Pressure Batch Reactor Engineering, Comp Sci, & Technology Homework 3
Constant volume versus constant pressure batch reactor Engineering, Comp Sci, & Technology Homework 0
Temperature change of water at triple point in a constant-volume gas thermometer Advanced Physics Homework 0
Heating gases at constant pressure or constant volume? Advanced Physics Homework 2
Constant Volume/Ideal Gas Introductory Physics Homework 1
