Calculating Shade Projection for Beach Sun Shade - Math Homework Solution
  • Thread starter Thread starter unknown101
    Projection Sun
The problem involves calculating the area of shade projected onto the ground by a sun shade erected on the beach. The shade has specific dimensions and is positioned at an angle relative to the ground, with the sun's rays assumed to be vertical.
  • Exploratory, Assumption checking
  • Participants discuss the interpretation of the angle and its relation to the shade and the ground. There are attempts to clarify the setup and the projection formula, with some participants expressing uncertainty about the problem's requirements.
The discussion is ongoing, with participants seeking clarification on the angle and the setup of the problem. Some guidance has been offered regarding the nature of the angle, but no consensus or resolution has been reached yet.
Participants note the absence of a diagram in the problem statement, which may contribute to confusion regarding the angle and projection. There is an emphasis on collaborative problem-solving without providing direct solutions.
unknown101
Two math students erect a sun shade on the beach. The shade is 1.5 m tall, 2 m wide, and makes an angle of 60° with the ground. What is the area of shade that the students have to sit in at 12 noon (that is, what is the projection of the shade onto the ground)? (Assume the sun’s rays are shining directly down).
I've attached the formula
I tried drawing a diagram with 2m at the bottom and the height being 1.5. I know I'm supposed to use the projection formula. After that I'm lost.
Just for my own clarity, does it make a 60° angle with the bit that goes in the ground or with the actual shade itself? Could you produce a diagram if this seems to be a silly question?
The Bob
With the piece that goes in the ground. The problem didn't come with a diagram because so you have to come up with your own.
60 degrees is an angle in an equilateral triangle. The edge of the shadow, with the sunlight coming straight down is at the perpendicular from the vertex. This is very close to being a trivial problem!
how would u solve this problem guys?
Hi hossai. Welcome to PF!
The idea of these threads is to help each other solve problems they have. So, if you'd like to venutre an attempt at the solution or method for solving this then we could discuss it further.
The Bob
  • · Replies 19 ·
