| Thread Closed |
Does the existance of relativity prove that gravity's wrong? |
Share Thread | Thread Tools |
| Mar4-09, 03:36 PM | #18 |
| Mar4-09, 03:55 PM | #19 |
Mentor
That 3 million years is about the same as the solar system's Lyapunov time. Beyond this time scale any predictions are pretty much garbage, even those with a full relativistic model. |
| Mar4-09, 04:25 PM | #20 |
I think that general relativity proved that gravity is correct. Consider a Mossbauer effect experiment, with a Mossbauer source on top of a 100 foot tall tower, and the Mossbauer detector at the base of the tower (and vice versa). Experiments show that the photons gain energy (just like Newton's apple) while falling from the tower, so either the source or the detector has to be moved vertically to compensate for the energy gained by the photons. Harvard did this experiment using the Fe^57 source mounted on a loudspeaker coil.
| Mar4-09, 05:20 PM | #21 |
Mentor
![]() The experiment you describe is interesting, and I appreciate that you posted it. I just couldn't let that first sentence slide
| Mar4-09, 07:44 PM | #22 |
Mentor
| Mar4-09, 08:30 PM | #23 |
| Mar4-09, 09:20 PM | #24 |
Mentor
Coulomb's law and Newton's law of gravity are superficially similar in that both are inverse square laws. That the two laws have a difference in sign (like charges repel but masses attract), that mass has magnitude only but charge has sign and magnitude, and a largish conglomeration of mass is close to electrically neutral makes gravitation and electrostatics considerably different. As noted by many, general relativity did not so much disprove Newtonian gravity so much as disprove that Newton's law of gravitation is universal. Newtonian gravity still has its place. There is no reason to use general relativity to model the motion of a satellite in low Earth orbit. Uncertainties in atmospheric drag, Earth's non-spherical nature, solid body tides, and even ocean tides vastly overwhelm the tiny error induced by ignoring general relativity. Strictly speaking, all scientific theories are incorrect. We just don't know yet where some of them (e.g., general relativity) are "wrong". Looking for absolute correctness in a scientific theory is asking too much of science. |
| Mar5-09, 01:55 AM | #25 |
| Mar5-09, 12:30 PM | #26 |
Mentor
| Mar5-09, 02:31 PM | #27 |
Mentor
Like Naty1 said, your original question was reasonable. Your post #7 is simplistic and silly. Your post #15 is completely contrary to the facts.
| Mar9-09, 02:41 PM | #28 |
The planet Mars has no global magnetic field (magnetosphere) and at best, it only has very isolated magnetic fields at various locations around the planet attributed to local iron concentrations. Even so, Mars manages to muster roughly 1/3 as much gravitational attraction as the Earth’s rate gravitational attraction regardless of an object’s orientation around its surface. How, in the complete absence of a global magnetic field, do objects free-fall to the Mars surface at the same rate regardless of their location? The answer is evident. Objects are attracted per the gravitational field of Mars, which is essentially uniform in all directions per the planet’s center of mass. Objects cannot be attracted to the planet’s surface via electromagnetism because Mars is lacking of a magnetosphere. This is essentially true of Venus as well. The Pioneer Venus Orbiter (1979~1981) measured the intrinsic magnetic field of Venus to be just 10^-5 that of Earth, comparatively, no magnetosphere to speak of. How then, does Venus produce the rate of attraction that it does in the absence of any significant magnetic field? Again, the means of attraction is by gravitational fields, not electromagnetism. You must remember to look at the entire picture when attempting to derive theories and they must in essence hold true when applied to all models. Gravity is present on all heavenly bodies to lesser and greater extents, but it is also clear that not all of these heavenly bodies possess a significant magnetosphere that could proportionately explain the heavenly body’s observed rate of gravitational attraction. Associated Links… NASA reference to Mars lack of global magnetic field… http://mgs-mager.gsfc.nasa.gov/ Additional NASA on Mars… http://science.nasa.gov/headlines/y2001/ast31jan_1.htm Mars… http://www-ssc.igpp.ucla.edu/personn...pers/mars_mag/ Venus… http://www-ssc.igpp.ucla.edu/personn...ers/venus_mag/ |
| Mar9-09, 02:50 PM | #29 |
Recognitions:
We're perfectly capable of thinking outside his 'box'. Tell me, why do you keep measuring your height in inches or centimeters when you know for a fact it's not an exact number of them? |
| Mar9-09, 05:58 PM | #30 |
![]() I don't remember gravity making electrons or protons fly off into space either(As if there aren't enough nails in the coffin) |
| Mar10-09, 07:04 PM | #31 |
| Mar10-09, 10:34 PM | #32 |
whos to say that gravity is a pull and not a push.
| Mar10-09, 10:41 PM | #33 |
Mentor
It's not a push.
| Mar10-09, 10:49 PM | #34 |
why is it not a push . i thought gr describes it as following the curves in space.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Does the existance of relativity prove that gravity's wrong?
| Would the existance of an omniscient being prove that free will is non-existant? | General Discussion | 86 | ||
| prove this wrong! | General Physics | 11 | ||
| I need your help to prove this wrong. | General Physics | 11 | ||
| try and prove this wrong | General Physics | 14 | ||
