| Thread Closed |
ultra long range projectile problem |
Share Thread | Thread Tools |
| Mar11-09, 09:39 PM | #1 |
Physics students know that if one fires a cannon ball and one assume that the earth is flat and the gravitational strength is constant for all height, we use the equation Range = (Vo2/g)* sin 2 θ, Vo = initial velocity, g = 9.8 m/s2 , θ = projection angle. How do we find the equation for range if we do not assume the earth is flat and gravitational strength is constant for all height, neglecting air resistance? Like for ultra long range projectiles. 2. Relevant equations 3. The attempt at a solution My attempt to solve the problem is to use polar coordinates instead of Cartesian coordinates. The origin is centered on the center of the earth and the y coordinate axis intersects the zenith of the projectile motion. I do not know if this is correct, but I assumed that the motion of the projectile follows a parabolic flight path. So the equation for parabolas in polar coordinates is r = { l \ {1 + e *cosθ} }, l = semi-latus, e = eccentricity. But after that, I have no idea how to do the problem. 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Mar11-09, 09:53 PM | #2 |
Mentor
That's a great idea! I wouldn't have thought of that right away, but what a natural approach.
Just solve for the landing point when the distance to the origin is the same R as the firing point. |
| Mar11-09, 09:55 PM | #3 |
Admin
While g is constant, what is the effect of the projectile's tangential velocity?
What happens if the projectile is fired in the direction of rotation of the earth? How about in the direction opposite the rotation of the earth? |
| Mar11-09, 09:56 PM | #4 |
wait, my math sux, I dun know how to do that.
| Mar11-09, 10:18 PM | #5 |
I forgot to mention to neglect rotation of the earth.
| Mar11-09, 10:29 PM | #6 |
Admin
Ah - so then one only needs to consider the intersection of a circle with a family of parabolas, which have the axis parallel to the diameter of the circle.
| Mar11-09, 10:35 PM | #7 |
| Mar11-09, 10:49 PM | #8 |
Mentor
| Mar11-09, 10:54 PM | #9 |
I think there's some confusion. Do NOT assume that gravitational strength is constant for all height. That should make the problem a little harder.
| Mar11-09, 10:56 PM | #10 |
Mentor
Show us your work. |
| Mar11-09, 11:35 PM | #11 |
Use polar coordinates. Superimpose r = radius of earth and r = { l \ {1 + e *cosθ} } (if you plot the graph of both equations together, you will see an ellipse on top of a circle with them centered on the same point). Then you can solve for θ (There are two answers, θ1 and θ2 ). Once you know θ1 and θ2, you know the intersection of the flight path of the cannon ball with the surface of the planet. The arc of the circle that connects the points where the circle and ellipse meet is the range. Range = 2*diameter*π2/(θ1-θ2). The question remains is how to determine l = semilatus rectum and e = eccentricity. These two values determine the shape of the parabola, and hence the flight path of the cannon ball. I know that these two values is somehow connected with the equation of gravity, which is F = GMm/r2. That's all I know how to do. |
| Mar12-09, 12:27 AM | #12 |
I forgot to mention something. Make sure initial velocity of the cannon ball and angle at which the cannon ball is shot at is in the equation to determine the range.
| Mar12-09, 07:54 AM | #13 |
Admin
Then there is the angle φ of initial projectile velocity with respect to the earth's radius or the tangent to the surface. There is also a constraint imposed by selecting a parabola (as opposed to some other form) to intersect with a circle. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: ultra long range projectile problem
| Projectile, Range, Maximum Height, Time of Flight Problem | Introductory Physics Homework | 1 | ||
| Old Farmer's Almanac: Long range weather forecasts | General Discussion | 0 | ||
| Long range effect of Nuclear Power plants. | Academic Guidance | 0 | ||
| article about long range artillery | Introductory Physics Homework | 12 | ||
