Current density constant in time implies charge density linear in time?
The discussion confirms that a constant current density (j) in time necessitates that the charge density (p) varies linearly with time, expressed as p(r,t) = p(r,0) + \dot{p}(r,0)t. This conclusion is derived from the continuity equation, which dictates that for j to remain constant, the rate of change of charge density (dp/dt) must also be constant. Thus, the relationship between current density and charge density is established as a direct consequence of the continuity equation.
  • Understanding of the continuity equation in electromagnetism
  • Familiarity with charge density and current density concepts
  • Knowledge of mathematical functions and their derivatives
  • Basic principles of electromagnetic theory
  • Study the continuity equation in detail and its applications in electromagnetism
  • Explore the implications of charge density variations on electric fields
  • Learn about the relationship between current density and electric fields in Maxwell's equations
  • Investigate time-dependent charge distributions and their effects on electromagnetic fields
Physicists, electrical engineers, and students studying electromagnetism who seek to understand the relationship between current density and charge density over time.
davethecello
Does current density being constant in time and the charge density NOT being constant in time imply that the charge density has to be a linear function of time? i.e of the form
[tex]p(r,t) = p(r,0) + \dot{p}(r,0)t }[/tex]
Can this be derived using the continuity equation alone?
Yes. For j to be constant in time requires dp/dt to be constant in time.
  • · Replies 23 ·
  • · Replies 22 ·
  • · Replies 21 ·
