Thread Closed
Equilibrium, charge, and reaction question
Share Thread Thread Tools
Mar12-09, 09:36 PM   #1
The figure shows an insulating ring and an infinite straight wire resting on the surface of an infinite plane. The wire is fixed in position, but the ring slides without friction on the surface of the plane. The ring is uniformly charged, with net positive charge Q. Initially, the wire carries a constant current I towards the top of the figure, and the ring is stationary. At time t=0, the current in the wire is reduced to I/2. Which of the following best describes the motion of the ring after the current is reduced?
1. The ring will spin clockwise and slide away from the wire.
2. The ring will spin clockwise and slide towards the wire.
3. The ring will spin clockwise and remain stationary.
4. The ring will not spin, but it will slide towards the wire.
5. The ring will spin counterclockwise and slide towards the wire.
6. The ring will spin counterclockwise and remain stationary.
7. The ring will not spin, but it will slide away from the wire.
8. The ring will spin clockwise and slide towards the top of the figure.
9. The ring will spin counterclockwise and slide towards the top of the figure.
10. The ring will not spin, but it will slide towards the bottom of the figure.
11. None of the above (please describe what does happen).
Hint: Think of the induced electric fields. If they can make current move, they can also apply a force or torque to a charge on an insulator.
3. The attempt at a solution
So obviously when the ring is stationary, the two objects are in static equilibrium, but I still don't know precisely how to answer this question. I think that if the current is halved, the electric field will be weaker.
What it comes down to is that I don't know the nature of two such objects given any conditions. Any links/explanations would be very helpful. My textbook, in my opinion, is fairly poor at conceptual explanations.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Thread Closed
Thread Tools
Similar Threads for: Equilibrium, charge, and reaction question
Thread Forum Replies
electricity and charge question, equilibrium, help! Advanced Physics Homework 4
Reaction that does not reach equilibrium Biology, Chemistry & Other Homework 7
quick question about equilibrium of a reaction Biology, Chemistry & Other Homework 6
[SOLVED] Games: Gravity is a chain reaction within an equilibrium of chaos& entro Beyond the Standard Model 1
A very specific equilibrium reaction... Chemistry 0
