What is the significance of the semicolon in the notation for parameter \alpha?
  • Context: Graduate
  • Thread starter Thread starter gnome
    Notation
The discussion revolves around the notation used for the parameter \alpha in the context of an exponentially distributed variable T^k_{s,i}. Participants are examining the significance of the semicolon in the expression \alpha = f_{s,i}(S^k_{s,i};\, t_k,\, T) and its implications for distinguishing between variables and parameters.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant notes that the semicolon separates variables from parameters in the notation, contrasting it with the use of a comma for other terms.
  • Another participant provides a general function notation example to illustrate the distinction between variables and parameters.
  • A subsequent reply questions the classification of t_k as a variable, suggesting it may be treated as a parameter instead.
  • A later response implies that the classification of t_k depends on the context of the function being discussed.
Participants express differing views on whether t_k should be considered a variable or a parameter, indicating that there is no consensus on this aspect of the notation.
The discussion highlights potential ambiguities in the notation and the definitions of variables versus parameters, which may depend on the specific context of the function.
gnome
Given this statement "[tex]T^k_{s,i}[/tex] is exponentially distributed, and the parameter [tex]\alpha[/tex] in the distribution of [tex]T^k_{s,i}[/tex] depends only on the maximum expected surplus [tex]S^k_{s,i}[/tex] of seller i on the length T of the trading period, and on [tex]t_k[/tex], the time elapsed in the trading period. We write this dependence as
[tex] \mbox{\Huge \alpha = f_{s,i}(S^k_{s,i};\, t_k,\, T)}[/tex]
In that last expression what is the significance of the separation of the [tex]S^k_{s,i}[/tex] from the [tex]t_k, T[/tex] by a semicolon, as contrasted with the separation of the latter two terms by a comma? It's clearly not accidental -- they follow this notation several times in the paper.
To the left of the semicolon are the variables, to the right are the parameters.
[tex] f(x) = m\cdot x + b[/tex] or [tex] f(x;m,b) = m\cdot x + b[/tex]
Thanks, that's good to know. But then, what I quoted above seems to be an abuse of that notation. [tex]T[/tex] is clearly a parameter, but wouldn't you consider [tex]t_k[/tex] (elapsed time) a variable?
That sounds like a question for your function, which seems to be saying that it's a parameter.
