Finding a Complex Matrix Square Root for a Set of Equations
The discussion revolves around finding a complex matrix square root for a set of equations involving complex variables and a real constant K. The original poster presents a system of equations that they believe can be represented in matrix form.
  • Participants explore the nature of the equations, questioning the use of the term "complex" and the connection to matrices. Some suggest simplifying the problem by setting one variable to zero to investigate potential solutions.
The discussion is active, with participants clarifying terminology and exploring different interpretations of the equations. There is an ongoing examination of the relationships between the variables and the potential for simplification.
There is a noted ambiguity in the equations regarding the use of complex numbers and the structure of the matrix. The original poster's equations involve four variables but only three equations, leading to questions about the degrees of freedom in the solution.
Dragonfall
*The subject should have been complex matrix square root.
I need to find one solution to the follow set of complex equations:
a*a+b*b = 1-K-K/2
a*b+c*d=K/2
c*c+d*d=1-K/2
where K is some real constant.
This is equivalent to finding a 2x2 complex matric M such that [tex]M^\dagger M=[/tex]
1-K-K/2, -K/2
-K/2, 1-K/2
I can't seem to do get started.
Are you using "complex" as a synonym for "complicated?" These are not linear equations, but I don't see any evidence that they involve complex numbers.
Is there some reason you wrote the expression on the right side of the first equation as 1 - K - K/2 instead of 1 - 3K/2?
Also, I don't see any connection to matrices.
Your system of three equations is in four variables, so at least one variable can be set arbitrarily. You might start by setting a to zero, and seeing what you come up with for b, c, and d.
"Complex" as in complex numbers. a* is complex conjugation. I realize now that it might have been confused with multiplication.
a*a+b*b = 1-K-K/2
a*b+c*d=K/2
c*c+d*d=1-K/2
Here is as close as I can get to your equations
[a b][a c]
[c d][b d]
a*a+b*b=1-k/2
a*c+b*d=k/2
c*a+d*b=k/2
c*c+d*d=1-k/2
Lets assume a lower triangle solution (AKA c=0)
|d|=sqrt(1-K/2)
|b|=(k/2)/sqrt(1-K/2)
angle(d)=angle(b)
|a|=sqrt(1-k/2-(k^2/4)/(1-K/2))
Now I think that all solutions can be found by multiplying a particular solution by all possible orthonormal transforms.
What's an "orthonormal transform"? Do you mean unitary matrices?
Yes. I guess I should say unitary matrix as according to Wikipedia it is more general.
  • · Replies 22 ·
  • · Replies 18 ·
