| Thread Closed |
What caused time to run slower in a field of gravity |
Share Thread |
| Mar19-09, 08:27 AM | #19 |
The proper method in all cases is to integrate the "proper" distance as mentioned. In GR this would always be the proper time elapsed; this can also included null geodesics (which contribute nothing). The integration path doesn't need to be a geodesic. Typically intuitive type of reasoning can be fooled since we have little experience in these realms. GR is mathematically consistent, so we need to bring our intuition into line with what the mathematics says. Mathematical consistency says nothing about whether it matches reality though. Ray |
| Mar19-09, 12:47 PM | #20 |
Presuming that your original expression is right then the density should be the constant; OTOH constant density is a stretch for the earth. Although not for a meteor. Ray |
| Mar19-09, 12:59 PM | #21 |
In the metric M is geometric (M=Gm/c^2), 2M being the schwarzschild radius of the object of mass and R being the overall radius of the object of mass. Based on this, as r tends to zero, R remains constant and none of the expressions appear to blow up. Which expression are you refering to?
| Mar19-09, 01:08 PM | #22 |
Okay, I will reexamine the result. It still seems strange to me that the expression uses Schwarzschild terms instead of density. The longer I think about the stranger it seems; probably a shortcoming on my part.
Ray |
| Mar19-09, 01:21 PM | #23 |
| Mar19-09, 08:40 PM | #24 |
I presume you are using Florides solution. I will have to wait until I move into my house and have a real computer to do a real analysis. This little laptop running Vista is really trying.
Ray |
| Thread Closed |
Similar discussions for: What caused time to run slower in a field of gravity
| Work caused by gravity | Introductory Physics Homework | 1 | ||
| Time does not run slower or faster | Special & General Relativity | 70 | ||
| Experiencing time faster rathe than slower | Special & General Relativity | 3 | ||
| gravity caused by curved space - am I right? | Special & General Relativity | 18 | ||
| Time changes in gravity field. | Special & General Relativity | 18 | ||
