Register to reply
Phase to Phase fault?
by XPTPCREWX
Tags: fault, phase
Share this thread:
XPTPCREWX
#1
Mar16-09, 10:04 PM
P: 97
In a 480v Three Phase Induction Motor.....what kind of educated guess or assumption can be made as a cause, when two of the three fuses blow? Is there any type of significance in two fuses blowing instead of just one in a three phase motor circuit?
If only one fuse blew it basically would mean there was a phase to earth fault,
what about two?.....phase to phase, im thinking?
Phys.Org News Partner Engineering news on Phys.org
New filter technology uses inert gas to bore holes in high-quality steel
Augmented reality helps in industrial troubleshooting
How wireless technology can dramatically improve ship safety
Averagesupernova
#2
Mar16-09, 10:33 PM
P: 2,528
If a 3 phase motor is overloaded, something will have to give first. So, suppose fuse #1 blows. Ok, no problem, but now we are feeding an already overloaded 3 phase motor with only 2 phases. So, much current is drawn, and another fuse blows. Now there is only one phase left and no longer a return path since any 3 phase motor I've ever seen does not use a 4th conductor to actually carry any current. So there is your answer. Probably doesn't help you much.
Register to reply
Related Discussions
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 3
Why do 3 phase balanced faults cause such high fault currents? Electrical Engineering 5
Phase, Phase Difference and Phase Shift General Physics 6
Alternator Problems (3 phase and single phase AC Motor) Engineering, Comp Sci, & Technology Homework 0
3 Phase System Line to Ground fault Fault current calculation Engineering, Comp Sci, & Technology Homework 1
