Register to reply
Circle of Curvature
by nns91
Tags: circle, curvature
Share this thread:
nns91
#1
Mar17-09, 08:30 PM
P: 301
I am given a space curve r(t)= t i + sin(t) j and point (pi/2,1). They ask me to find an equation for the circle of curvature.
2. Relevant equations
Kappa, T, N, not sure
3. The attempt at a solution
So I have found the radius of curvature which is row= 1/kappa= 1 at the given point. I have also found out T which is the unit tangent vector. Do I have to find the unit normal vector also ?
How do I write the equation ? will it just be (x-pi/2)^2 + (y-1)^2 = 1 ??
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
lanedance
#2
Mar17-09, 08:50 PM
HW Helper
P: 3,307
Hi nns91
what do you need to define a circle in the plane?
- a radius
- a circle centre
The equation of a cirlce of centre (a,b) and radius r is
[tex] (x-a)^2 + (y-b)^2 = r^2 [/tex]
You have your radius from
[tex] r = \frac{1}{\kappa} [/tex]
Also are you sure \kappa is 1? how did you get this?
how do you find the centre of the circle? It is not (pi/2,1). This is a point on your curve. Think about the unit normal direction.
lanedance
#3
Mar17-09, 08:52 PM
HW Helper
P: 3,307
you should also consider whether you curve is unit speed or whether you need to normalise...
nns91
#4
Mar17-09, 09:16 PM
P: 301
Circle of Curvature
I calculate Kappa and got like sqrt(1+cos^2(t)) / sin(t). Then I substitute pi/2 for t and get 1. Am I right ??
I still don't get the relationship between center of circle and the unit normal direction.
My curve is not a unite speed curve I think since it is r(t) instead of v(t)
lanedance
#5
Mar17-09, 09:34 PM
HW Helper
P: 3,307
try drawing your curve and imagine where the circle sits, the tangent of the curve will match the tangent of the circle
the normal direction will point toward (or away) from the centre of the circle
you curve is unit speed instanaeously at that point (calulate |dr/dt|, but not in general so you may need to be careful with your calcs and check what this affects... i'm not totally sure without looking back at the equations which I don't have handy
Also i'm not too sure how you got it, but I think your curvature value is correct, if you are speaking about absolute curvature. If we are talking about signed curvature need to be careful as it could be + or - depending on how things are defined.
nns91
#6
Mar17-09, 09:42 PM
P: 301
WIll the normal direction point toward the center of the circle ?
lanedance
#7
Mar17-09, 11:07 PM
HW Helper
P: 3,307
either directly toward or directly away depending on your parameterisation & curvature definition
nns91
#8
Mar17-09, 11:13 PM
P: 301
Then how do I find the center of the circle base on the normal vector ?
lanedance
#9
Mar18-09, 01:55 AM
HW Helper
P: 3,307
you have a point on the circle (ie the point on your curve) a direction to the centre (normal vector) and a radius (from you curvature).... should have everything you need
nns91
#10
Mar18-09, 06:58 AM
P: 301
so the radius is the distance from the center to the point, so do I use the distance formula then ?
Register to reply
Related Discussions
Curvature and Osculating circle Calculus & Beyond Homework 0
Radius of curvature of an offset circle Calculus 0
Simple circle circle collision detection General Math 6
Curvature Circle Proof Calculus & Beyond Homework 0
Geodesic Curvature (Curvature of a curve) Differential Geometry 8
