Equation of a Curve Passing Through (0, 9)
  • Thread starter Thread starter locachola17
    Curve
The problem involves finding the equation of a curve that passes through the point (0, 9) and has the property that the slope at any point on the curve is twice the y-coordinate of that point. This relates to differential equations and the behavior of curves in calculus.
  • Participants discuss the implications of the slope being twice the y-coordinate and how to express this as a differential equation. There are attempts to clarify the relationship between the slope and the curve's behavior at various points.
Participants are actively engaging with the problem, exploring the formulation of the differential equation and discussing the steps needed to solve it. Some guidance has been provided regarding the integration of the equation, but no consensus on the final form of the solution has been reached.
There is an emphasis on understanding the properties of the curve rather than simply finding a solution. Participants are reminded to show their attempts at solving the problem to receive further assistance.
locachola17
A curve passes through the point (0, 9) and has the property that the slope of the curve at every point P is twice the y-coordinate of P. What is the equation of the curve?
Hi locachola, welcome to PF!:smile:
We're not here to do your homework for you, we're here to help you learn. You must show some attempt at a solution, in order to receive help...
Hi locachola17 wlecome to PF
The idea of the forum is to help with your working... so any ideas on how to get started?
as a hint, the line
"has the property that the slope of the curve at every point P is twice the y-coordinate of P"
can you write this line as an equation?
okay well at the point (0,9) the y-coordinate is 9
if the slope is twice the y-coordinate, the slope is 18?!
Sure, but what about at any other point (x,y) on the curve? What does that tell you about dy/dx for this curve?:wink:
thats for that single point...
but the question says its true for every point on the line... how would you write this to show it for every point on the line...?
remeber the slope is given by the derivative y'(x) = dy/dx
dy/dx is 2y
locachola17 said:
dy/dx is 2y
Right, so y(x)=____?
No it doesn't...It says for every point on the "curve"...the curve is not a line:wink:
y(x)=y^2
locachola17 said:
y(x)=y^2
That makes no sense, you have a separable differential equation for y(x): [tex]\frac{dy(x)}{dx}=2y(x)[/tex]...how do you usually solve a separable DE?
you integrate both sides?
How do you determine [tex]\int y(x)dx[/tex] when you don't know what y(x) is?
No, you separate varaiables first and then integrate:
[tex]\frac{dy}{dx}=2y\implies \frac{dy}{y}=2dx[/tex]
Now you can integrate...
