Register to reply
Hexane's solubility in crude oil
by soopo
Tags: crude, hexane, solubility
Share this thread:
soopo
#1
Mar18-09, 01:32 PM
P: 226
Does hexane dissolve in Crude oil?
My attempt
I know it dissolves in fats and to some oils.
I am not sure whether it means crude oil too.
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
Borek
#2
Mar18-09, 02:59 PM
Admin
Borek's Avatar
P: 23,533
Do you known what kind of compounds are present in crude oil? How they are relataed to hexane?
chemisttree
#3
Mar18-09, 02:59 PM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,724
You might be fascinated to know that hexane is isolated from crude oil.
soopo
#4
Mar18-09, 04:12 PM
P: 226
Quote Quote by Borek View Post
I think that crude oil consists of old fossils which are in the liquid form.
For example, the marine fossils are in the liquid.
soopo
#5
Mar18-09, 04:13 PM
P: 226
Quote Quote by chemisttree View Post
I found from Wikipedia that hexane is isolated from crude oil by distillation.
This means that the isolation process depends on the boiling points of the substances in the initial crude oil.
This also means that if hexane could dissolve in crude oil, you could not use distillation to separate the substances.
Therefore, I suggest that hexane cannot dissolve in crude oil.
Borek
#6
Mar18-09, 04:52 PM
Admin
Borek's Avatar
P: 23,533
You are so off it is even hard to start helping...
Read about http://en.wikipedia.org/wiki/Crude_oil first.
What kind of mixtures can be separated by destillation?
soopo
#7
Mar19-09, 10:00 AM
P: 226
What kind of mixtures can be separated by distillation?
Hydrocarbons such as alkanes, cycloalkanes and aromatic hydrocarbons.
Borek
#8
Mar19-09, 03:16 PM
Admin
Borek's Avatar
P: 23,533
So alcohols can't be separated? Nor ethers?
Do you know what 'miscible' means?
chemisttree
#9
Mar19-09, 04:28 PM
Sci Advisor
HW Helper
PF Gold
P: 3,724
Quote Quote by soopo View Post
I've never seen a fossil in crude oil.
You probably haven't ever seen crude oil before. It is a solution of a large variety of mostly hydrocarbons (some sulfur compounds and nitrogen-containing compounds as well). The key term is 'solution'. Miscibility is a prerequisite for 'solution' don't you agree?
soopo
#10
Mar20-09, 03:28 PM
P: 226
Miscible means that two different solutions can mix together such as water and ethanol are miscible since they mix in all properties.
Hexane is a hydrocarbon. Crude oil consist a variety of different hydrocarbon chains.
I know that methane is a gas and the oil sources contain it.
The more carbon the hydrocarbon chain contain, the greater boiling point.
This suggests me that hexane is a liquid.
Wikipedia tells us that hexane is immiscible in water.
However, it is apparently miscible in other hydrocarbons.
Since crude oil does not only contain hydrocarbons at least initially, I suggest that hexane is soluble in hydrocarbons.
It is not apparently soluble in sulfur which crude has initially.
Borek
#11
Mar20-09, 03:39 PM
Admin
Borek's Avatar
P: 23,533
You don't have to guess whether hexane is a liquid or not, it is much simpler to check. Or to remember which hydrocarbons are gaseous, which are liquid and which are solid at the room temperature.
How much sulfur in crude oil? Is it one of the main components, or just impurity?
soopo
#12
Mar20-09, 05:00 PM
P: 226
It is an impurity which needs to removed for environmental reasons at least from bensin.
Crude oil contains sulfur about 1%.
It is not one of the main components.
Hydrocarbons are the main components.
Borek
#13
Mar20-09, 05:50 PM
Admin
Borek's Avatar
P: 23,533
So is the hexane solubility in the sulfur relevant to the problem, or not?
soopo
#14
Mar22-09, 03:06 PM
P: 226
It is not relevant to the problem, since it can be removed from crude oil.
It seems that pure crude oil consists only hydrocarbons.
We know that non-polars love non-polars.
Hexane seems to be soluble in crude oil.
Register to reply
Related Discussions
Predicting the price of crude oil Social Sciences 27
Crude Oil Biology, Chemistry & Other Homework 2
HELP solubility product determine solubility of lead 2 chloride mol/L and g/L Biology, Chemistry & Other Homework 2
A Crude Thermometer General Physics 11
