Thread Closed
Seperate CO2
Share Thread Thread Tools
Mar19-09, 09:33 PM   #1
Seperate CO2
Use the same device to separate singly charged CO2 having 12C and 14C. What are the radii of curvature?
This is a follow up question based on a HW problem I answered last week. The original problem was this:
A doubly charged helium atom is accelerated by a voltage 2700V. What will be its radius of curvature if it moves in a plane perpendicular to a uniform 0.340-T field?
2. Relevant equations
r = mv/qB
3. The attempt at a solution
I solved the original problem by saying
q = 2e for the doubly charged He
On accelerating through V volts
1/2mv^2 = qV = (2e)V
Where v = velocity acquired
v = squrt(4eV/m) = 2*squrt(eV/m)
I figured out the mass to be m = 7.26 x 10^-26kg
And then plugging into the formula.
Now this new follow up question is throwing me off a little bit. Based on the question asked and info given how would you seperate the CO2? And what would be the charge q of the CO2? Im thinking it would be the 6e from C + 8e(2) of O2 = 22e. Is this correct? Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar19-09, 09:37 PM   #2
Recognitions:
Homework Helper Homework Help
No it's only the extra charge you put on to isonise it - generally just one e-
Mar19-09, 09:52 PM   #3
Quote by mgb_phys View Post
Oh ok I get it now. Thanks!
Thread Closed
Thread Tools
Similar Threads for: Seperate CO2
Thread Forum Replies
can i seperate co2 Biology, Chemistry & Other Homework 1
Spring Constant and Work (2 seperate problems) Introductory Physics Homework 6
2 seperate sounds Classical Physics 3
[SOLVED] Should Europe Be Considered A Seperate Continent? Earth 52
Should Politics and World Affairs be a seperate forum? Forum Feedback & Announcements 9
