Thread Closed
Race cars - Torque vs Hp - The Undiscovered Country (for many)
Share Thread Thread Tools
Mar27-09, 12:31 PM   #52
Regarding your original question, yes it is more clear now. The answers I gave are still the same for everything else. But the fact that its in a higher RPM range and is well geared, both should accelerate the same as long as they ar eboth in their peak power band. The engine with more torque has a wider band, so will pull better from lower rpm. The revver will do all of its useful work at higher rpm.
You are still confused over torque and horsepower. You said I could be way off by looking at only that, this is not the case. As hp is calcualted directly from torque, to it really makes no difference if we use power or torque, the sums will be different but we'd ge tthe same answer.
Power = Torque * angular velocity.
I prefer using torque purely as that is the acutal real world driving mechinsm of the engine. The point you make that torque figures alone are pretty much useless is true, without knowing the engine speed they arent helpful. Using the torque value a trear wheel is a more useful figure from a design perspective, as the size of the wheel has no bearing on the torque, but it will affect RWHP reading and therefore acceleration. So say you calcualte your acceleration times with a 14 inch wheel on a dyno, if you are using RWHP you'd need to re run it as the figure would no longer be valid for the new wheel. By using the engine torque you eleiminate this issue. Although is technically not strictly correct you can say that RWHP determines the torque at the rear wheel, but again this makes it sound like power dictates torque when really its torque dictating power.
You are correct in that to use the engine torque, you'd need the gear ratio and rpm of the engine. This for practical purposes makes the RWHP reading from the dyno more convenient to use, however this also leads people into the false sense that the driving force is power and not torque.
By using Engine T * Gearing * %Losses = Wheel torque
and Using the RWHP
Its making more yes you are correct, its making more power so the forces a the rear wheel will be higher. This is only becuase the torque is being applied more rapidly.
Im going to have to dig out my books on integrating curves. I'll have a read up tonight.
So summerise: both ways will give you the same answer. Using the power and vehichle speed is more convenient to calcualte quickly. but using the engine torque is a more powerful tool for analysing engine performance.
Mar27-09, 12:57 PM   #53
Gnosis, Thanks for the response. The purpose of the questions were to look at engine hp curves (and torque curves) as they apply to vehicles. There are a lot of instances where broader HP curves from lower peak torque engines produce more rear wheel torque . Ive been asking this board, how to describe this situation with proper, less confusing terminology. So far, we all know that with equal HP curve shapes, if the gearing is appropriate and proportional, two same cars will accelerate at exactly the same rate at any vehicle speed, regardless of the numerical "engine torque" value.
Below, I go into what causes the "F" in a=F/m. sure the force at the engine or the rear tires is what causes the acceleration, but isnt the power available, caused by the ignition of gasses, release of potential energy to kinetic energy, the cause for the force. If I have 746watt-seconds available, 1-hp second, cant i use 7,460watts for 1/10th of as second , creating 10hp, and lifting 5500lbs 1/10th of a foot, or 550lbs 1ft, in 1/10 of a second?
since work=energy, doesnt the the energy determine the quantity of work that can be done, and if the rate of work to be done is faster or slower that would be higher or lower HP.
Sure, the torque or force is what creates the acceleration. But to achieve the force, you need something to cause it. power, watts ,etc, come in many forms. Is gravity the force that causes the acceleration, or is the size of the planet that causes the gravity? :)
I consider the engine' abiltiy to process fuel (potential energy) as its power potential which generates torque . If it spins at 1,000,000rpm and produces 1ft/lb of torque, it isnt very torquie. but, the HP is huge. harness the power effectively with gears and the rear wheel torque will be determned by the engine power at any speed. I feel like Im talking in circles. so, maybe you can straighten me out. Thanks!
Let me insert my comments below with the >>>>>>>>>>
Quote by Gnosis View Post
Zanick, the matter hasn’t been reduced to a philosophical debate in the least. Your supposition concerning horsepower and torque is quite simply backwards. Torque isn’t a factor of horsepower rather; horsepower is a derivative of torque. You must first produce torque if you are to “calculate” a “horsepower rating” for the engine.
>>>>>>>>>>>>>>>>>>while this is true, when looking at strictly engine torque (not the resultant force or torque at the driven tires, it might not be a direct indicaton of accelerative potential, unless you know engine speed. So, HP ratings and curves can be a better indication of acceleration potential. Yes, at the engine Hp is the rate that the force does work. Its all about rate of doing work, which is hp but its cause by the force at the rear tires, not the engine. (meaning the engines numerical torque value can be misleading as a comparitive factor)
Horsepower is an intangible quantity that cannot be measured directly, but more importantly, horsepower isn’t a “force”. Horsepower is simply a rating of how much work can be performed over time and distance. It is “calculated” per the torque measured since torque CAN be measured directly in ft lbs. For instance, when an engine is stated as having 200 HP, it is merely a rating of how much work can be performed at a given RPM per the engine’s available torque.
>>>>>> agreed, but isnt power also the rate of change of kinetic energy as well. so , the rate of change of speed of the drums can be calculated to show HP without knowing torque.
I know that the force is makeing the acceleration, but as far as what causes the force, isnt that caused by the energy source and its potential energy? (a 75amp/second 10v battery that produces 1hp-second or 750watt-seconds? Ill tie back into this below.)
The dyno measures torque by applying a known braking force to the dyno’s rotating drum. When the vehicle’s drive wheels accelerate the dyno’s drum under this braking force up to a given RPM in a given time, it reveals the torque being applied by the vehicle’s drive wheels, as it would require a given torque to have accomplished this rate of drum acceleration in the time recorded.
>>>>>>>>>>for a brake dyno this is true, but there are inertial dynos that are just drums weighing up to 3000lbs and are free spinning. they only measure the acceleration change of the drum and calculate everything from that.
Force produced in a Combustion Engine
Consider where the combustion engine actually produces its force. It is per the optimized A/F ratio ignited per each power-stroke, as the piston and its connecting rod are forced downward by the expanding hot gases in the cylinder with the other end of the connecting rod applying its force to the crankshaft in a manner that provides leverage to rotate the crankshaft and produce crankshaft torque. So, torque is the accelerative component, not horsepower.
>>>>>>>>>>>>>>but doesnt the rate of expanding gasse the cause for the force? without the energy, power/t available, you dont have any force? correct?
You need to get horsepower out of your head and acknowledge the actual source of the vehicle’s acceleration; that being torque. Horsepower is only a rating of how much work can potentially be performed at a given RPM per the available torque.
>>>>>>>>>>>Doesnt the equation Acceleration=power/momentium point to acceleration being determined by power, which creates the force? this is where i was suggesting it gets a little bit philosophical. :) I understand that the force creates the acceleration. a=F/m. I get that. But, if we are going to dump 1 oz of gas in an engine and get the energy out of it, we can get lots of rpm and a little torque or visa versa. in the end, the force we will generate at the driven wheels will be multiplied through a gear box so that we maximise power, not engine torque at the rear wheels and the resultant torque at the rear wheels will be proportional to the power. This torque can be made from low engine torque or high engine torque, based on the RPM range needed to create max power at any particular vehicle speed.
Horsepower is a “rating” of potential work that can be accomplished, but it is NOT an actual force
For instance, my workouts had me moving approx 30,000 pounds of free weights a distance of 3 feet in an hour’s time. This can be given a horsepower rating HOWEVER, that horsepower rating does not imply an actual force used. It merely specifies a total of 30,000 pounds was moved 3 feet over a span of one hour (a given weight moved a given distance over time).
>>>>>>>you did work during the hour. it can be rated in watt-seconds, KWh or Hp-seconds with are unit measures of work, not rates of doing work. rates of doing work wold be if you then lifted 550lbs in 1 second 1 foot. that would be using 1 hp. we could then calculate the acceleration caused by that force over that period of time.
In fact, some weight movement was several hundred pounds per rep while things like curls were more around the 95 to 115 pounds. Again, horsepower doesn’t specify a given force rather; it implies a given amount of work that can potentially be accomplished.
>>>>>>> but the rate of which the force does work, is HP. you bench press 550lbs ove 1 foot in 1 second, you needed 1hp to do it. If you use pulleys to do it slower and it takes 4 seconds to do this work, then the HP required was only 1/4 hp, but the force at the weight was still 550lbs being lifted over 1 ft.
Hopefully this will provide the insight you need to resolve your confusion associated with horsepower. Unfortunately, those who tend to adore horsepower and have long confused its meaning have a most difficult time relinquishing their love for its mighty-sounding namesake, when it’s actually “torque” that should be held in highest accord.
>>>>>>>>>>>>This is ironic as ive been fighting the torque folks for 10 years in the field of racing, and im a very small minority. There are countless discussions on the topic, all feble arguments becuase in the end, torque is a part of HP. HP can determine torque at the rear wheels, even though torque at the engine multiplied through the gears does this too.
I understand that the force is what does work. or torque in the rotational plane. If we look at constant variable gear boxes, where will engines operate to maximize acceleration, peak engine torque or peak HP???? right, peak engine HP! this will yeild the maximum amount of torque at the rear wheels at any vehicle speed, right?
I demonstrated the example below back in my mini-bike building days. It demonstrates the significance of an engine’s torque.
Firsthand Example:
I used a 1.5 HP lawnmower engine to power a mini-bike and I geared it to yield a top-speed of 35 MPH while on flat ground with my body weight of 140 pounds. However, while riding at 35 MPH on flat ground, I came to one of the steepest streets in my neighborhood. My mini-bike steadily lost speed and would not make it all the way up to the top of the steep hill. When I hit the hill, the engine was at its upper rev range therefore producing its 1.5 HP, so why could it achieve 35 MPH on flat ground, but not make it to the top of the steep hill?
>>>>>>>>>>>>>>>becuse the hp requried to climb that hill was not availble from the 1.5HP engine. HP is the rate of doing work. that amount of fuel and air was not enough to do the job of lifting you and the mini bike up the hill at that speed. Power=Forcex speed. so , you slowed, got out of the power band and could have come to a complete stop. however, with right gear, you could climb that hill at its maximum potential (P=Fv) which would be at max hp of 1.5hp. sure , you could gear it down even further and go slower producing more torque, but all that would do would be to accelerate to a slower speed faster and then top out at max rpm at a slower speed, thus now you back off the throttle and you continue up the hill at a slower speed, and lower HP setting and lower torque requirement.
Answer: The engine lacked sufficient torque to accomplish the climbing of the steep incline. The incline imposed additional loading on the crankshaft, so the engine’s crankshaft steadily lost RPM. As its crankshaft slowed, less A/F mixtures were ignited per second as a result, so less over all energy was provided per second, which further slowed my ascent. It must be realized that “IF” the engine’s torque were sufficient to climb the steep hill in the first place, the engine would have never slowed down. A 2.5 HP combustion engine remedied the issue,
<<<<<<<<<<<<yes, more HP required to accelerate or create the greater rate of work. I get this.
as it produced greater torque and even had enough extra torque to start out from a dead stop up the steep hill. From a dead stop (engine just above idle), it couldn’t be the extra HP yielding the more than adequate acceleration up the hill; it was a direct result of the extra torque provided by the 2.5 HP engine.
>>>>>>> the hp at just above idle would then have more Hp available comparitively than the other 1.5hp engine. yes, I get it, more rear wheel torque was developed then.
Point: A given task requires a given minimal torque to accomplish the task. If less torque is produced, then it makes no difference what the “horsepower rating” is, the task will not be achievable.
>>>>>>>>>I dont quite follow you. Now, If the the hp rating is high enough, the minimal torque can be acheieved. ?????? I dont understand the point.
Mar27-09, 01:06 PM   #54
Your responces to Gnosis' questions show that you've not changed your thought process about this one bit.
"I know that the force is makeing the acceleration, but as far as what causes the force, isnt that caused by the energy source and its potential energy? (a 75amp/second 10v battery that produces 1hp-second or 750watt-seconds? Ill tie back into this below.)"
the force at the contact patch is caused by the torque on the wheels NOT THE POWER. Power is a way of visualising what the torque is doing. This is why it is more of an abstract concept albeit one that people are more familiar with. Caused by the torque deliviered by the engine, from burning the fuel. so talking about heat into the engine can also be used, but the trype of work that the engine does is torque. and this is the crucial thing you must understand.
everything else is an application of that torque generated.
Mar27-09, 01:07 PM   #55
I totally agree, that rear wheel torque is equal to the engine torque though the ratios at any vehicle speed. If folks talked in terms of that, the world would be a much better place, but instead, folks talk in terms of engine torque as a comparitive value. Is not, an as you seem to agree, it depends on engine rpm and then gear ratios to be of any value.
area under the engine torque curve will be meaningless without gear reduction ratios mixed with rpm. area under the rear wheel torque curve, through the gear box is correct, but who has this data? using area under the HP curve or Watt-seconds, would be a much easier way to optimize vehicles acceleration over a operational speed range, right?
I have a dyno run (http://www.physicsforums.com/showpos...16&postcount=1) that shows a graphical representation of two engines, one with more torque than the the other, even though their HP's are equivilant. clearly, the lower torque engine has more accelerative potential. this is not common, but possible. I have actual dynos of cars Ive raced that have a similar message, that sometimes, the lower torque engine can have a broader HP curve and produce more rear wheel torque at any vehicle speed. I just want to be able to explain why, correctly! thanks!
Mk
Quote by xxChrisxx View Post
and Using the RWHP
Mar27-09, 01:13 PM   #56
and by the way, if you were comparing two different engines. It'll be more correct to compare bmeps as they are dimensionless.
Mar27-09, 01:14 PM   #57
I get it, its getting to be less and less of a chicken and egg thing. force is what causes the acceleration. got it. Hp is a measure of of the rate the force does the work. HP is a vision into what the pontential force is though right? or is it just a distilled version of what you need to really look at, an indicator when you dont have the time or the information to see the actual torque created at the rear tires.
Lets say you have a dyno, (inertia). you dont have sparksignal, you only have the car, and the gas pedal. what is the output? you get rear wheel torque, and Power, vs MPH as you floor it and hit the rev limiter, but you never know what the engine profile is of torque, correct? It could be 5000 or 10,000rpm redline.
I guess that is my point. for years I was muliplying gear ratios with the torque curves for every gear doing manual integration. Years later, i just started optimizing HP and accomplished the same thing.
Thanks for the comments. you brought me back to reality. awesome!
Mk
Mar27-09, 01:25 PM   #58
If you only had rolling road data without rpm signal, you'd be forced to use the power method. This is perfectly valid.
Now we've got that sorted we can look at the practical side of this. Lets talk about a track with a slow hairpin onto a midlength straight. Both cars have 4 gears, one prodeuces 50 Nm more torque than the other. You could gear the cars differently to give the same low down acceleration from the corner. The car with the lower torque would need to be geared shorter to allow it to be running in the higher rpm range.
As you have a shorter gear ratio in first and the same ratio of ratios (if you know what i mean) so that the acceleration performance ws the same the higher torque car would have less top speed.
However! If you geared the cars for the same speed in each gear, the lower torque car would likely fall off its peak power band, and would accelerate slower away from the corner, but begin to catch the higher torque car down the straight.
This is not a problem if you had a lower torque engine with a 6 speed box, as you could gear for lower accelration and still maintain top speed.
you are making the classic mistake that lots of people have made for race engines. They tune their horsepower and gears so it looks perfectly on paper (fom the dyno), but this wont necessarily transfer well to the tack.
Mar27-09, 03:15 PM   #59
Thanks for the dyno validation, now the good stuff
I think you might be confused when you start looking at same ratios to achieve same vehicle speed in each gear. If the HP curves were the same, the acceleration performance would be the same at ANY speed on any track at ANY time. (even though one engine had 60NM less torque than the other) Of course, that lower torque engine has proportioally deeper gearing per gear and proportionally higher rpm ranges per gear. This is the classic example that there is NO difference, not in top speed, not in accelerative force anywhere.
Do we agree there?
Now, your point below that is valid that most high torque lower rpm engines have a boader HP curve, so the peaky HP curve, high rpm, lower torque engine usually has less grunt out of corners when the rpm is less than even the gear to gear rpm drop percentage. (e.g. Most are 27% rpm drops per gear, but you can be at near 55% of max rpm on some corners)
now, the closer ratio gear boxes can bridge this gap, almost entirely. in fact, they can even be an advange with being able to use more available peak HP.
As far as race cars on the track, I have 10 years of racing experience that points to not making the mistakes of some of my competitors. what i have done is maximized my gearing and HP design to fit more tracks without changes. (i.e. broader hp curve). As long as you know the rpm range, and the time spent at those rpm ranges, you can determine the best gearing to optimze available HP. (or rear wheel torque throguh the gears if you want to go through the additional math). by optimizing time spent at or near max HP, you get the greatest acceleration on the track. There are few trade offs , such as do you want to have to shift in an area of the track that might upset the car or take time for a shift, calling for an immediate downshift too soon afterward. those are considerations that can be tuned with small gearing changes. (ie tire size, rear end changes that shift the entire gear ratio set up or down)
mk
Mar27-09, 03:19 PM   #60
As a note , you guys have got me looking at the power scene a little differnet. It is a highlevel indicator of what torque you have available at the rear tires. (as multiplied though the gear box). It doesnt cause the motion, Force does. Its a snap shot of what you have. However, with cars we have only engines with HP ratings. (Kw ratings like with elecric motors) with that and torque values, we get a picture of the kind of force we can apply to the ground at any given vehicle speed. the engine torque is not a good indicator unless it has the rpm attached to it, and then we can determine exactly what torque /force will be able to be achieved at any vehicle speed. without it, HP can allow us to work backward and find that engine torque at the rpm and vehicle speed to determine Force! Hows that guys?
Now, in maximizing force at the rear wheels at any speed, how do you use the time factor to know if you are maximizing force on the track? Ft-lb-seconds? If that is the better, more clear terminology, Ill use that instead of watt-seconds or HP-seconds or something in that relm.
mk
Mar27-09, 03:43 PM   #61
That sounds exactly on the button for the physics terminoligy for what is going on. I didnt know you had that much racing experience, i've not got that much practical experience and most of what I know comes from engine dynos. So thats why I would always lean towards torque figures.
You can either integrate the torque at engine (gives an indiation of engine work) or horsepower curve to give an indication of work. In this case the horsepower curve would be the more useful for finding what you want to know. I'm really not sure what the units would be for that though, im just assuming Power.S.
For the rear wheel, time based one. I just dont know im afraid, i'll try looking it up but most of my books are purely engine based and are unlikely to have this information. I think a trip to the library is in order.
As a performance indicator are you thinking of inegrating for an acceptable power band. So say find the area between 80% max power?
I'm still a little confused as why what you mean when you say the horse power curves are the same. As that to me means the torque must be the same as the graphs overlay perfectly. Do you mean that when the x axis is scaled, the curves have the same trend?
Also you mention getting a broader HP curve, so you sacrifice peak HP for gains along more of the rev range. (in effect maximising the area under the power curve). This is essentially the same as altering the torque curve to sustain at higher rpm (I think). My friends is acutally better than me at this, i'll ask him about it tonight.
I'm really enjoying this discussion, its making me think quite hard and polish up on stuff i've not read in quite a while.
Mar27-09, 06:01 PM   #62
Thanks Chis, I think Im back on track now. (literally, going racing tomorrow too! )
Anyway, as far as the intgration of the power curve, yes, I think 75% would probably do it for sportscar and closer to 80% for factor race cars or spec open wheel type cars.
Sorry about the confusion of the HP curves. I mean they are the same shape, with the x axis scaled. So, when both A car and B car are coming off a turn at 55% of max rpm, they both have the same HP created by :) engine torque thorugh the gears, making the same rear wheel force to the ground. (it might not even be same wheel torque, if the tires are different diameters. (all part of the gearing part of the equation, right?)
as far as the broader HP curve, in the example, the HP peaks were identical, but one curve just had more HP over the operational range. Generally, this is more true for a high torque engines, but occasionally, you see one that has a slightly broader HP curve. generally, it means the other high torque engine has much upside potential for mods.
Ive enjoyed the talk as well . Trust me, very few, but the motorsport top engineers get this stuff, even at this basic level. Its nice to get grounded here with the right thinking and terminology. I worked in the industrial controls arena for 12 years as well, so I have a great handle on the basic stuff. (torque, gear ratios and efficiency, basic motion control profiles,etc). Delt with all sorts of flavors of small electric motors and their associated electronics, including servos and stepmotors. So, I have the high level understanding, but the devil is in the details. :) . Obviously for racing, its an avantage to know how to optimize your equipment performance on a given race day!
Thanks,
mk
That sounds exactly on the button for the physics terminoligy for what is going on. .
Mar27-09, 08:16 PM   #63
Quote by zanick View Post
Mk
Just when I think you're maybe finally getting it, you go right back to that association you have with horsepower and force as per your last sentence above.
Horsepower isn't a "vision" or "insight" into the potential force. All force in the combustion engine is strictly produced by torque and torque alone. Torque IS measureable on a dyno. Horsepower is merely a rating of how much "WORK" (not force) can potentially be accomplished per a given RPM via the available torque of the engine. "Work" and "force" are two entirely different quantities just as horsepower and torque are entirely different.
Horsepower should only be thought of as a rating, as in a "horsepower rating", a work rating.
Try to grasp the concept of “horsepower rating” from this next example:
YOU could potentially twist a ratchet (thereby apply some measure of torque) all day long. This also means we could actually give you a horsepower rating of some kind rated per an entire day’s work. Let’s assume that the absolute torque limit that you can apply per your ratchet is 200 ft pounds and the conveyor belt you’ve been manually cranking with your ratchet has only required 20 ft lbs (piece of cake). This conveyor belt is carrying buckets of material to the top of a silo, then dumping the contents. Suddenly, someone accidentally overloads one of the buckets on the conveyor belt with 400 pounds of material. Doh!
At this point, you HAVEN’T lost your willingness to work neither have you lost your “horsepower rating” (that work which you are capable of accomplishing per day). You simply lack the strength to apply any more than 200 ft pounds of torque to lift the excessive 400 pound load. Since torque is the ONLY factor causing the conveyor belt’s movement and you lack the torque to lift the 400 pound load, all work has ceased. If you stepped over to an identical conveyor belt that didn’t have the excessive 400 pound load, you’d be able to continue at your rated horsepower rating for the rest of the day. Insufficient torque is the issue here, NOT insufficient horsepower.
That's why I stated it WASN’T lack of horsepower that prevented my 1.5 HP mini-bike from climbing that steep incline; it was the engine’s sheer lack of torque, as torque is the ONLY force being produced by a combustion engine and I cannot state this enough. Horsepower is a work rating, torque actually causes the rotation and acceleration of the crankshaft.
Apr2-09, 06:26 PM   #64
I understand your push for clarifying that it is the force that does the work. But, it is the HP "rating" as you call it, that can indicate the potential force at any speed. (if you don't know the force, as power=fv. In your analogy, clearly if 1.5HP doesn't give the force you need to climb the hill, more power will give more force. (and I know you are going to say, if I give I more force, it will have a higher power rating as a result ;) ). But, I don't understand why HP isn't an indication of force at any vehicle speed. Im talking about HP and its indication of a force's ability to do work. This is why I was leaning toward watt-seconds (or HP-seconds) as a determinant factor and useful term on the subject of automobile comparisons. If you have a battery , its energy potential is rated in KW-Hours. (same thing as Hp-seconds, watts-seconds etc) That battery can give you the power to be able to lift 550lbs in 1 second over 1 foot. (if this 10v battery is 74amp/second, 1hp-second battery, 746watt-seconds) 746w-seconds, 74amp-seconds, 20ma-hour, etc) . This power rating tells me how much work I can do and how fast I can do it. I can lift 550lbs in 1 foot in 1 second or 1100lbs 1 foot in 2 seconds, or 225lbs, 1 foot in 1/2 second. Its a power limit of how fast you can accelerate a mass at a given velocity, or the rate of doing 'work' . Again, I understand that the force does the work, but you don't really need to know it to get an acceleration of a mass at a velocity, right? Rate of change of kinetic energy is one example I can think of where if I know this, the answer can be power, without the knowledge of force or torque. A chassis dyno has drums and can measure hp with out using a torque value, even though a torque value is easily produced from the change of sped of the drums. Without an engine speed input, engine torque could be any value, so the output is engine HP and rear wheel MPH.
Now, we might have glazed over the main question here, but when folks look at HP ratings of vehicles, or torque, which is more meaningful as an indication of potential rear wheel forces at any speed? Certainly engine torque is only an indication, if we are talking about comparing two equal HP cars, with grossly different engine torque and RPM values. If you don't look at the gearing and vehicle speeds, HP will be able to be compared by only plotting both HP curves on one another. if they are same shape for an given range of vehicle speed, the cars will accelerated the same (assuming the same car and gear boxes adjusted for same range of speeds). In other words, both identical cars have gear boxes that allow for the same MPH speed of the cars in each gear. Average power, but more importantly, HP-seconds being a determinant factor on which car will accelerate faster. In other words, if two curves have the same area under the usuable rpm range, but one has more area under the top rpm are vs the lower rpm area in the usable range, the one with he area in the higher rpm range will have more "Hp-seconds" and will accelerate an equal car faster through a wide range of vehicle speed
The point I was trying to make earlier, was that even an integration of the HP curve doesn't exactly find the answer, as this is due to the varying time spent at the higher rev areas. Area under the engine torque curve doesn't work, as most engines make most their torque below an area where they would even be operating in. The most rear wheel torque (after the gear box reductions and torque multiplications) would be found at the maximum amount of HP available at any vehicle speed.
Getting back to your mini bike analogy, if you don't have over 1.5hp or some force at the rear wheels , you are not going to be able to climb that hill. the rate of change of kinetic energy or adding potential energy (mini bike climbing hill) can not be met by the power source and resultant forces from the rear wheel on the road. If we were using the battery, we could turn up the power setting and climb the hill. (using more amps) the capacity would be reduced, but the system would be using a faster rate of doing work, and use more power. !nstead of 1100watt-seconds of power, you could be using 2200watt-seconds (or near 3Hp) to keep that current rate of speed, while climbing the hill. 2 x the amp draw, 2x the power and 2x the torque to the drive wheels. Clearly, the force has been increased by increasing the current draw, which is by definition a higher rate of doing work (higher power). How is this logic not correct?
These are the questions many are looking to have answered in the right terms.
Thanks,
Mk
Apr2-09, 07:07 PM   #65
Recognitions:
Homework Helper Homework Help
Assume mini-bike weighs 60 pounds. Weight of rider and mini-bike is 200 lbs. To climb a 20 degree hill, it will take sin(20) x 200 = 68.4 pounds of force to climb the hill (ignoring drag factors here, assuming rear wheel horsepower is 1.5).
If the rear wheel horsepower is 1.5 hp, then you need to solve:
1.5 = 68.4 x speed / 375
speed = 8.22 mph.
In order to climb a 20 degree hill, the mini bike would have to be geared down so it's makes 1.5 rear wheel horsepower at 8.22 mph.
If the hill was vertical, with the mini-bike attached to a chain going up the side of the hill, then it would lift 200 lbs at 2.81 mph
Apr2-09, 07:10 PM   #66
Your thinking is correct but you have the wording wrong zanick.
Rate of change of kinetic energy wont tell you the force nor acceleration. K.E = .5mv^2
Just because they use the same terms doesnt make them mathematically compatble. The dyno doesnt acutally measue energy, as energy cant be directly measured.
The thing you are describign for the dyno is rate of change of momentum of the drum. momentum = mv
Dy differentiating this you get the magic formula of F = ma.
Apr2-09, 07:30 PM   #67
Thanks Chris,
But if acceleration = power/(mass x velocity or a=P/p , the rate of change of momentium would be proportionally higher from 50-60mph as it would from 60 to 80mph and so would the force for the two speed ranges. However, the power would be much higher at the higher speed range. Thats why I seemed to remember power equaling rate of change of kinetic energy, not momentium. I agree that the rate of change of momentium would get you to "Force".
so I guess what I'm saying is that the rate of change of kinetic energy gets you power and thus acceleration at any given velocity, and from power you could get force. (working backward )right?
mk
The thing you want is rate of change of momentum. momentum = mv
Apr2-09, 07:38 PM   #68
This is where are going wrong. you are correct that Power is not the rate of change on momentum. But what the dyno actually measures, and what it outputs on a screen is not the same thing. From what it measures it does some mathematical operators. to give out a nice convenient power figure. To same you messing around calcualting it yourself.
The dyno:
1) measures the rate of change of anguar momentum of the drum in a given time.
2) this gives the acceleration of the drum.
3) From f=ma you can find the force at the wheel giving said acceleration.
4) deterimes the speed at the tire = surface of drum = radius times angular velocity.
5) determines the power by multplying force time speed (at the tire contact patch).
This is thats going on from what the dyno measures, what the computer then calcualtes and operates. Then produces the power figures.
This cannot be done the other way round as energy cannot be directly measured (see this link:http://en.wikipedia.org/wiki/Energy#Measurement) to get acceleration directly.
We know that as energy is a concept that is inferred, so is power. You can mathematically operate the equations once you konw evreything to give you what you want, but that doesnt mean you can do it in reality.
Also i'll discuss the climbing a hill thing with you in a bit, as thats a tricky one to talk about over a forum. Its another time that figurees can be misleading. you look at the figures and see one thing, but reality tells you something different.
Thread Closed
Thread Tools
Similar Threads for: Race cars - Torque vs Hp - The Undiscovered Country (for many)
Thread Forum Replies
Our Undiscovered Universe? Special & General Relativity 4
No Country for Old Men General Discussion 2
Undiscovered physics General Physics 8
Why do race cars use wide tires? Brain Teasers 7
