Do light waves change over distance within a vacuum?
In summary, the amplitude of a wave of light does not change when it does not encounter any matter. However, in a strong gravitational field, such as near a massive object, a gravitational redshift can occur where the wavelength of light increases. In a uniform spherical mass and light universe, the light waves will decrease in amplitude and increase in wavelength as they spread out radially. Over cosmological distances, the wavelength can also increase due to the expansion of the universe, known as cosmological redshifting. This is why the James Webb telescope, which is an infrared telescope, is used to observe the "first light" of the universe. On a smaller scale, such as on Earth or within the solar system, the wavelength of light does
xcrunner2414
25
Specifically, does the amplitude of a wave of light change if it does not encounter any matter?
Science news on Phys.org
we can have a gravitational redshift were light will change wavelength
moving away from a stong gravitational field ,
So, if the universe consisted of a uniform spherical mass and light, when the light waves emanate radially away from the mass would the light waves decrease in amplitude or only wavelength? What exactly happens?
k i know that when the light travels outward into a weaker gravitational field
the wave-length becomes longer and the frequency increases but I am not sure
about amplitude
As a spherical wave spreads out, without touching anything, the total energy in it does not change. However, it is spread over a greater area (the area of a spherical surface is proportional to the square of the radius) so the intensity at any point on that surface decreases as the inverse square.
Over a great enough distance (and we're talking cosmological distances here--millions of light years, i.e. the distance between galaxies), the wavelength gets longer as well. Owing to the expansion of the universe, cosmological redshifting (as opposed to regular redshifting from receding objects) occurs.
http://en.wikipedia.org/wiki/Cosmological_redshift#Redshift_velocity_and_recessional_velocity
The planned James Webb telescope is an IR telescope because the "first light" (emitted when the universe was a wee billion or two years old) has traveled so far that it's been stretched out and is now in the infrared.
http://en.wikipedia.org/wiki/James_Webb_Telescope
...But for the most part (on Earth or within the solar system, for instance), the wavelength doesn't change to any measurable extent.
1. What are light waves?
Light waves are a type of electromagnetic radiation that can travel through a vacuum or a medium, such as air or water. They are characterized by their wavelength, frequency, and energy.
2. How do light waves travel through a vacuum?
Light waves are able to travel through a vacuum because they are not mechanical waves that require a medium to propagate. Instead, they are electromagnetic waves that can travel through empty space at the speed of light.
3. Do light waves change over distance within a vacuum?
No, light waves do not change over distance within a vacuum. They will maintain their properties, such as wavelength and frequency, as long as they are not affected by external factors like objects or gravitational fields.
4. Can light waves be affected by other factors in a vacuum?
Yes, light waves can be affected by other factors in a vacuum. For example, if they pass through a strong gravitational field, their path may be bent. They can also be affected by objects, such as mirrors, that reflect or refract the light.
5. How does the distance of light waves affect their intensity?
The intensity of light waves does decrease as the distance traveled increases, but this is not due to any change in the waves themselves. It is simply a result of the spreading out of the waves over a larger area. This is known as the inverse square law, where the intensity is inversely proportional to the square of the distance from the source.
  • Optics
  • Optics
