Penny sits on top of a frictionless sphere, urgent please
by malta
Tags: frictionless, penny, sits, sphere, urgent
malta
malta is offline
#1
Mar23-09, 05:38 PM
P: 20
At the top of a frictionless sphere of radius R a penny is given a push to speed x. At what angle, measured from the vertical does the penny leave the surface?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
LowlyPion
LowlyPion is offline
#2
Mar23-09, 05:47 PM
HW Helper
P: 5,346
Welcome to PF.
What considerations do you think need to be made?
Maybe start with what condition determines when it will lose contact?
sArGe99
sArGe99 is offline
#3
Mar23-09, 05:47 PM
P: 133
Normal reaction = 0 when the block has left the surface. Did you try that out?
malta
malta is offline
#4
Mar23-09, 05:51 PM
P: 20
I have no clue how to start this problem, I look at a similar problem here (http://www.physicsforums.com/showthread.php?t=260338) but i could not figure out what the last post tried to say. This is going to be a problem on my test tomorrow and I need to figure it out. Do any of you guys have aim or msn?
LowlyPion
#5
Mar23-09, 05:58 PM
HW Helper
P: 5,346
Well admittedly that was a brilliantly constructed suggested direction to go in solving the problem.
Maybe you should consider using some of that to figure it out?
Doing homework through other venues is not something encouraged here. And if that is too subtle, it's just not permitted, even through PM.
malta
malta is offline
#6
Mar23-09, 06:00 PM
P: 20
The thing is that i dont care much for the answer, I want help on starting the problem so I can work it on my own. Would you mind pointing me in the right direction please?
sArGe99
sArGe99 is offline
#7
Mar23-09, 06:02 PM
P: 133
You have to work on it. If you don't, then what is the point in doing homework? You should at least try.
LowlyPion
#8
Mar23-09, 06:10 PM
HW Helper
P: 5,346
Quote Quote by malta View Post
Well ... I'd start with that even if I did suggest it myself.
malta
malta is offline
#9
Mar23-09, 06:11 PM
P: 20
I have been working on it, I've been stuck on the damn problem for 3 days now, I know that energy and momentum are conserved, but I cant seem to translate that into actual equations : /
Edit: ok i think im getting somewhere.
I know that the point where the particle leaves is = 0, so mgcosx-ma=0 right?
So Cosx = a/g
Also Etot = Ekin + Epot= .5mv^2 - mgh= 0
=====> v^2= 2gh
But im stuck in a loop now haha
malta
malta is offline
#10
Mar23-09, 06:22 PM
P: 20
Am I getting closer to figuring this out? haha
LowlyPion
#11
Mar23-09, 06:31 PM
HW Helper
P: 5,346
So Cosx = a/g
=====> v^2= 2gh
OK it's good knowing that momentum is conserved and perhaps you will need that elsewhere on your exam. But ... not on this problem.
Now the mgCosθ term is the weight component of gravity. But isn't what you are interested in balancing the outward centripetal acceleration? mv2/R ?
malta
malta is offline
#12
Mar23-09, 06:40 PM
P: 20
Ok so this is independent of the mass of the penny and of g. So would i have
mgcosx= mgh + mv^2/R??
LowlyPion
#13
Mar23-09, 06:42 PM
HW Helper
P: 5,346
Part of the problem with that equation is that 2 of those terms are Force, the other energy.
malta
malta is offline
#14
Mar23-09, 06:46 PM
P: 20
Gotcha so it would only be
mgcosx= mv^2/R? But what would i solve for?
LowlyPion
#15
Mar23-09, 07:00 PM
HW Helper
P: 5,346
Since V is, as you found, a function of h, and so is θ ...
malta
malta is offline
#16
Mar23-09, 07:14 PM
P: 20
Alright, so since v^2 = 2gh you substitute and get Cosx= 2h/r. But how is theta a function of h??
LowlyPion
#17
Mar23-09, 07:28 PM
HW Helper
P: 5,346
... Cosx= 2h/r. But how is theta a function of h??
Even better then eh?
Looks like you can do a lot of substituting.
malta
malta is offline
#18
Mar23-09, 07:31 PM
P: 20
Yeah but with what? what can i substitute cosx with?
Register to reply
Related Discussions
block slides from rest from the top of a fixed frictionless sphere Introductory Physics Homework 2
Particle sliding down a frictionless sphere Introductory Physics Homework 0
frictionless sphere, falling particle Introductory Physics Homework 2
A spool of mass M sits upright on a table... Introductory Physics Homework 13
Bug lands on a frictionless sphere. Show that the Bug leaves head when... Introductory Physics Homework 7
