Cancellation property of addition of natural numbers
The discussion revolves around proving the cancellation property of addition for natural numbers, specifically that if \( m + k = n + k \), then \( m = n \). The original poster mentions the requirement to use induction in their proof.
  • Participants discuss the base case of the induction and the implications of \( m + 1 = n + 1 \). There are questions about the validity of subtracting \( k \) from both sides and whether the induction should be applied to \( k \) or the values \( m \) and \( n \). Some participants express frustration with the nature of the proof and its perceived obviousness.
The discussion is ongoing, with various participants exploring different interpretations of the problem and the nature of the proof. Some guidance has been offered regarding the use of ordering in natural numbers and the importance of definitions in proving properties of addition.
There is a mention of a mental block regarding the learning process and the challenge of proving seemingly obvious statements. Participants are also questioning the definitions of addition being used in the context of the proof.
zcdfhn
I have to prove that for all k,m,n [tex]\in[/tex] [tex]N[/tex] that if m+k = n+k, then m=n.
The problem mentions that I must prove this by induction.
I did the base case k = 0: If m+0 = n+0, by identity m=n.
Then I attempt to show that m+1 = n+1 implies m=n, but I am stuck, I don't see how induction can be used to prove this and then next predicate that m+k = n+k implies m=n.
Any help would be greatly appreciated, and thanks in advance.
"show that m+1 = n+1 implies m=n"
Can you subtract 1 from both sides? Not sure if that's allowed in this step of the proof. It's less general than subtracting k from both sides of the original question, but not by much...
The problem didn't say you had to induct on k, though.
As an aside... doesn't
m+k = n+k implies m = n​
follow straightforwardly from
m+1 = n+1 implies m = n​
What is your definition of addition for natural numbers?
I just don't get this. This is exactly the problem I have with some of the "proofs" that I am given to construct in textbooks, they are obvious before the fact, and that is a horrible way to teach a concept.
m + k = n + k | -k
m = n
Of course that is true! there is no natural number k so that 3 + k = 4 + k!
I have a mental block or something which prohibits me from learning a method by examples where I don't actually need to use the method to get the desired result!
End-of-rant
k
If you're allowed to, use the fact there is an ordering on the natural numbers.
i know what you mean kenewbie, I'm struggling with the same issue on analysis proofs... but there in lies the twist, if you can't prove something that appears obvious, how can you prove something less obvious, that probably relies on your obvious friend?
i think its about breaking it right down to what actually is assumed eg. your axioms... and what follows as a logical consequence from those axioms alone. Otherwise seemingly simple assumptions could get swept up in your reasoning without a concrete base for them
probably wrong place to hijack somones question to discuss it, but interested on anyone else's thoughts on this
Well, your first example uses k = 0. Your next step you said that your k was 1 greater than your previous value of k, k = k + 1. If you prove that this next step is also true and that this process of getting to the next natural number is valid, then you just proved it, I think. I haven't done much of this kind of problem.
I asked before, what definition of addition are you using? I don't see how you can prove anything about addition of natural numbers without using the basic definition.
  • · Replies 19 ·
