| Thread Closed |
[Chemistry] Determine the concentration of h2o2 by redox titration! |
Share Thread | Thread Tools |
| Mar24-09, 02:32 PM | #1 |
You are provided with a solution of hydrogen peroxide which is known to be approximately ‘100-volume’. Plan two experiments that would enable you to determine the exact concentration of H2O2 in mol dm-3, in this solution. One of your experiments should involve a redox titration with potassium manganate (VII). The other experiment should not involve a titration. 2. Relevant equations 2KMnO4 (aq) + 5H2O2 (aq) + 3H2SO4 (aq) --> 2MnSO4 (aq) + K2SO4 (aq) +5O2 (g) + 8H2O (l). 2H2O2 --> 2H2O + O2 3. My questions Why is KMnO4 it's own indicator? What is meant by 100-Volume and how can i put it into context? What catalyses the disproportionation of h2o2? 4. The attempt at a solution The end point of this reaction is noted by a pale pink colour. No indicator is required as the solution goes pale pink once all of the H2O2 has reacted. I know this has something to do with the redox chemistry but im not exactly sure. 100-Volume one i believe this means one volume of h2o2 realeses 100 volumes of oxygen when catalytically decomposed. what does it mean by volume? And how can i use this to determine conc of h2o2 as the second experiment. Liver? |
| Mar26-09, 04:46 PM | #2 |
Admin
No special chemistry involved - once you add excess of permanganate, its strong color is well visible in the solution. |
| Apr1-09, 04:46 PM | #3 |
Hi Borek, I was wondering if you could help me. I'm doing the titration of H2O2 with KMnO4 in order to determine the concentration of H2O2. I understand that H2SO4 is required in the reaction, now if I dissolve the KMnO4 in H2SO4 does that count? Also, if I dissolve 2.5g of solid KMnO4 in 47.5cm3 of H2SO4. Will this be the resulting concentration?
2.5/ 50 = 0.05 mol dm-3. Also, if I dissolve the KMnO4 in the acid, the number of moles of H2SO4 as required in the reaction (3) will not exist will it because the KMnO4 and the H2SO4 have been combined? I appreciate any help! thank you! |
| Apr1-09, 05:06 PM | #4 |
Admin
| Apr1-09, 06:06 PM | #5 |
I'm sorry, I'm really confused! How would I make a solution of KMnO4 of concentration 0.05 mol dm-3 by dissolving the manganate in H2SO4? How much H2SO4 would I need?
| Apr2-09, 02:36 AM | #6 |
Admin
| Thread Closed |
| Tags |
| chemistry, redox, titration |
| Thread Tools | |
Similar Threads for: [Chemistry] Determine the concentration of h2o2 by redox titration!
| Determining conc of H2O2 by titration | Biology, Chemistry & Other Homework | 6 | ||
| Chemistry - titation with old and new H2O2 | Biology, Chemistry & Other Homework | 5 | ||
| Titration method to determine HCl concentration in a mixture | Chemistry | 7 | ||
| REDOX titration of bleach help! | Chemistry | 4 | ||
| Chemistry - Titration, Redox, Combining Equations | Biology, Chemistry & Other Homework | 5 | ||
