What is the direction of the magnetic field at point P?
The discussion revolves around determining the direction of the magnetic field at point P based on the behavior of a positively charged particle moving in different directions. The context involves concepts from electromagnetism, specifically the interaction between charged particles and magnetic fields.
  • The original poster attempts to apply the right-hand rule to deduce the direction of the magnetic field based on the forces experienced by the particle in different directions. Some participants question the coordinate system used and suggest that a misunderstanding of the right-hand rule may have led to an incorrect conclusion about the magnetic field's direction.
The discussion is ongoing, with participants providing clarifications about the right-hand rule and coordinate systems. There is acknowledgment of a potential error in the original poster's reasoning regarding the orientation of the axes, but no consensus on the final answer has been reached.
Participants note the importance of using a right-handed coordinate system and discuss the implications of using a left-handed system in the context of the problem.
ehilge
A positively charged particle moving in the direction of the positive x-axis feels no magnetic force when it passes through point P. When moving in the direction of the positive z axis, the particle experiences a magnetic force in the positive y direction when it passes through point P. Thus the magnetic field B at point P is directed along:.
F=q(v x b)
right hand rule
Since the particle feels no force when traveling in the direction of positive x, (v x b) must be 0 and the only way this happens is if the angle between the is the angle between the velocity and B field is 0 or 180. So the B field must be parallel to the x axis. Now the question states when the particle moves along the + z axis, it feels a force in the positive y direction. Due to the right hand rule, I believe that this must mean the b field is in the -x direction. Fingers in the direction of the velocity (+z), thumb in the direction of the force (+y), curl fingers towards the B field, which then must be the -x direction.
However, the answer is not the -x axis. Could you please show me where I went wrong in my reasoning and help me find the correct answer?
Thanks!
Your description of how you solved this is correct, but for some reason you came up with -x instead of +x.
I am just guessing, either you used your left hand by mistake, or you are picturing the x,y,z axes incorrectly.
If the axes are set up properly, then +x × +y = +z
EDIT
LowlyPion beat me to it.
Yup, after reviewing that, it appears that I definitely used a left hand coordinate system. Thanks for your help.
  • · Replies 31 ·
