Unpolarized light and Polarizers
  • Thread starter Thread starter hellogirl88
    Light
The discussion focuses on the behavior of unpolarized light passing through two polarizing filters. The first filter is set at an angle of θ1 = 80 degrees from the y-axis, while the second filter is at θ2 = 65 degrees. The correct formula to determine the final intensity of light after passing through both filters is I2 = I0 * 0.5 * cos²(θ1) * cos²(θ2 - θ1). The user struggles with applying this formula correctly, particularly in understanding the effect of the first polarizer on unpolarized light.
  • Understanding of unpolarized light and its properties
  • Knowledge of polarizing filters and their orientation
  • Familiarity with the mathematical representation of light intensity
  • Basic trigonometry, specifically cosine functions
  • Study the derivation of the Malus's Law for polarizers
  • Explore the effects of multiple polarizers on light intensity
  • Learn about the polarization of light in different mediums
  • Investigate applications of polarizers in optical devices
Students and professionals in physics, optical engineering, and anyone interested in the principles of light polarization and its applications in technology.
hellogirl88
Unpolarized light propagating along the x-axis from the left in the image above encounters two polarizing filters in a row. The first filter is oriented with its polarization axis at θ1 = 80 degrees from the y-axis, and the second is oriented with its polarization axis at θ2 = 65 degrees from the y-axis. What is the final intensity of the light as a fraction of the original (pre-filter) intensity?
Ive tried doing this problem in every conceivable way possible and I can't get it right.
Please help! I know you have to use a variation of I2=I0*cos^2(theta1) *cos^2(theta2-theta1), but this isn't correct, so what am I doing wrong?
Thanks!
Since the light is initially unpolarized, what is the effect of the first polarizer?
  • · Replies 25 ·
  • · Replies 20 ·
11K
