Smallest distance between object and image - lens.
  • Thread starter Thread starter Kruum
    Image Lens
The discussion revolves around finding the smallest distance between an object and its real image formed by a lens, given the focal distance of the lens. The problem involves understanding the relationships defined by the lens formula and the characteristics of real and virtual images.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between object distance, image distance, and focal length using the lens formula. There are attempts to derive the minimum distance and questions regarding the nature of real versus virtual images, including their characteristics and positions relative to the lens.
The discussion is ongoing, with participants sharing their attempts at a solution and seeking clarification on the definitions and implications of real and virtual images. Some guidance has been offered regarding the mathematical approach, but there is no consensus on the interpretation of the results or the definitions involved.
Participants express confusion over the definitions of real and virtual images, indicating a need for further exploration of these concepts. There are references to varying information encountered in learning materials, which may contribute to misunderstandings.
Kruum
Find the smallest distance between the object and a real image, when the focal distance of the lens is [tex]f[/tex]
[tex]\frac{1}{s}+ \frac{1}{p} = \frac{1}{f}[/tex], where [tex]s[/tex] is the distance of the object from the lens and [tex]p[/tex] is the distance of the image.
I'm not even sure, what I'm trying to do here, since the definition of a real and virtual image is a bit vague to me. But I've got something...
Let [tex]D=s+p[/tex] be the desired distance. From the equation above we get [tex]p = \frac{sf}{s-f}[/tex] so [tex]D= \frac{s^2}{s-f}[/tex]. Then [tex]\frac{ \partial D}{ \partial s}= \frac{2s^2-2sf-s^2}{(s-f)^2}=0 \Rightarrow s=0[/tex] or [tex]s=2f[/tex]. We get the same for [tex]p[/tex], so the distance would be [tex]D=4f[/tex]. Is this correct and does this apply for the minimum distance only or are the real image and the object always equal length from the lens?
You have just arrived at this value as a condition for an extremum (or a stationary value). What do you feel should be the answer? The value is correct, by the way . Can you find values of s and p such that [itex]s+p\neq4f[/itex]?
Not understanding the distinction between a real and a virtual image is not very conducive to learning Physics. Please read up or ask for help here.
That's the thing, I have read and listened and either misunderstood or then have had contradicting information. First I learned that the magnification for real image is m<0, the image is up-side down, and for virtual image m>0. Now I'm taught that virtual image always appears on the other side of the lens (or mirror). For converging lenses the image appears on the other side of the lens with m<0. :rolleyes:
hi there! I'm someone else asking the same question. so is the answer 4f? I don't understand what you mean by extremum and find the values of s and p so that it cannot equal 4f.
  • · Replies 19 ·
