Work and Mechanical Energy & Moment of Inertia Derivation?
The discussion focuses on deriving the expression for the moment of inertia using work and mechanical energy principles. Key equations include the work of friction, potential energy (U), kinetic energy (K), and the relationship between linear and rotational motion. The final expression for the experimentally determined moment of inertia is given as I = r^2(m((gt^2/2s) - t) - mf). The derivation involves manipulating equations for kinetic and potential energy, emphasizing the role of angular acceleration and effective mass.
  • Understanding of work-energy principles in physics
  • Familiarity with moment of inertia concepts
  • Knowledge of rotational dynamics and angular acceleration
  • Basic proficiency in algebra and equation manipulation
  • Study the derivation of the moment of inertia for various shapes
  • Explore the relationship between linear and angular motion in detail
  • Learn about the conservation of energy in mechanical systems
  • Investigate the effects of friction on mechanical energy transfer
Students in physics courses, educators teaching mechanics, and anyone interested in the applications of work and energy in deriving physical properties like moment of inertia.
danyalasdf
We did something very similar to this in lab
http://webenhanced.lbcc.edu/physte/phys2ate/2A LAB HANDOUTS/Moment of Inertia.pdf
Use Work and Mechanical Energy to derive the expression for the experimentally determined moment of inertia.
Wf= work of friction = Delta E = Ef - Ei
Wf= work of friction = Uf + Kf - Ui - Ki
U= Potential Energy
K = Kinetic Energy
Kf = (1/2)(m + mf)(Vf)^2 + (1/2)(I)(omegaf)^2
I = Moment of Inertia
Omegaf = angular acceleration
Average Velocity = v = (Vf + Vi)/(2)
If necessary
s=(1/2)*a*t^2
Torque= F*r= m*r*a
T= (mf + m)(g - a) = tension
Ui= mgh
Uf= mfgh
K(rotate) = (1/2)(I)(omegaf)^2
K(linear) = (1/2)(m + mf)(Vf)^2
Experimentally Moment of Inertia
I=r^2(m((gt^2/2s)-t) - mf)
Trying to get to this ^
mf= mass effective not much meaning just mass in kg
If it confusing the gt^2 is divided by 2s then it is subtracted by t and multiplied by r^2 and then minus mf
Wf = work of friction = Uf + Kf - Ui - Ki
The final potential energy and initial kinetic energy are both zero so this only leaves
Wf = Kf - Ui
Wf = ((1/2)(m + mf)(Vf)^2) + (1/2)(I)(omegaf)^2 - mgh
Wf = (1/2)(m + mf)(s/t)^2 + (1/2)(I)((s/t)*(1/r))^2 - mgh
Wf = (1/2)(m + mf)(s^2/t^2) + (1/2)(I)((.5*a*t^2)/(t) * (1/r))^2
Wf = ((1/2)(m + mf)((1/2)*(a*t^4)*(t^2)) + ((1/2)(I)(a*t) * (1/r))^2
Wf = ((1/8)(m + mf)(a^2 * t^2) + (1/8)(I)((a^2 * t^2)/(r^2))
Wf = (1/8)(a^2*t^2)((m + mf) + (I/r^2))
So...what is your question?
  • · Replies 28 ·
