Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Number Theory
Reply
image sum of distinct primes Share It Thread Tools Search this Thread image
Old Mar29-09, 01:47 PM                  #1
chhitiz
chhitiz is Offline:
i observed that every composite no. with exception of 4 and 6 can be expressed as sum of distinct prime no.s. eg: 200=103+97 100=53+47 25=13+7+5
is this true? is there any theorem stating as such?
Old Mar29-09, 11:41 PM                  #2
AUMathTutor
AUMathTutor is Offline:
Re: sum of distinct primes
Interesting question!
It seems true. Maybe you could prove it using induction?
The base cases could be integers from 1 to 20, say, by just showing the sums.
Then you could assume that it works for all composite numbers up to a composite number k.
Then does it work for the next composite number? Well, look at the largest prime number less than it. If composite - prime is not 1 or 4 or 6, then the sum can certainly be expressed as prime + (sum for the difference composite - prime, which can definitely be done... if the difference is prime, just take the prime, otherwise, the inductive hypothesis covers it). If the difference is 1 or 4 or 6, try the next prime number below the one you just tried. If this isn't 4 or 6, do the same thing. If it is, try the next lower prime number. And etc.
21 = composite, 19 = prime, diff = 2, done with sum = 19 + 2.
22 = composite, 19 = prime, diff = 3, done with sum = 19 + 3.
24 = composite, 23 = prime, diff = 1. Try 19 = prime, then diff = 5 and done with 19 + 5.
25 = composite, 23 = prime, diff = 2, done with 23 + 2.
26 = composite, 23 = prime, diff = 3, done with 23 + 3.
27 = composite, 23 = prime, diff = 4, try 19 = prime, diff = 9, done with 19 + psum(9) = 19 + 7 + 2.
etc.
This is just a sketch, but I think it should work. Does anybody have any comments?
Old Mar30-09, 12:19 AM                  #3
CRGreathouse
CRGreathouse is Offline:
Recognitions:
Homework Helper Homework Helper
You can prove this with Bertrand's postulate.
Old Apr4-09, 05:43 PM                  #4
mathmate
mathmate is Offline:
Yes, indeed.
It also follows from Bertrand's postulate that the number of such distinct primes does not exceed log2(N), where N is the original number to be decomposed.
Am I correct?
Old Apr4-09, 06:43 PM                  #5
epenguin
epenguin's Avatar
epenguin is Offline:
Recognitions:
PF Contributor PF Contributor
This is almost identical to 'Goldbach's conjecture' which is more than two and a half centuries old, famous, and has never been proved, so you are unlikely to.
Old Apr4-09, 08:08 PM                  #6
mathmate
This one is 'easier' in the sense that there is no limit on the number of primes that make the sum, just that they are distinct, whilw Goldback's conjecture restricts to two primes. It seems to me that Bertrand's postulate is sufficient for the proof.
image image
Reply
Thread Tools
Similar Threads for: sum of distinct primes
Thread Thread Starter Forum Replies Last Post
factors of product of n distinct primes de_brook Number Theory 7 Mar10-09 11:43 AM
Distinct Eigenvalues samurye Precalculus Mathematics 4 Oct20-08 07:38 AM
Let A be A set of n Distinct Elements. nowimpsbball Calculus & Beyond 2 Jan25-08 12:24 PM
distinct primes Benzoate Calculus & Beyond 1 Aug30-07 09:20 AM
(distinct eigenvalues) help! JerryKelly Calculus & Beyond 12 Dec7-05 06:58 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
