| Thread Closed |
How did WWI Planes Fly? |
Share Thread |
| Mar30-09, 02:46 PM | #35 |
Recognitions:
| Mar30-09, 04:28 PM | #36 |
Recognitions:
http://www.4p8.com/eric.brasseur/glider2.html Some small indoor models also have flat wings: ![]() |
| Mar30-09, 04:38 PM | #37 |
Mentor
All you need to do to get a cambered airfoil in a balsa glider is cut a curved slot in the fuselage. It would also help keep the wing in place. I do remember adding/increasing(?) the camber on mine by wetting down the wings and warping them, plus sanding the leading and trailing edges. |
| Mar30-09, 05:03 PM | #38 |
Recognitions:
Straight slot on most of these:
![]() Do a web search for free flight glider, or free flight indoors, and you find a few hits. The model aircraft equivalent of watching grass grow or paint dry. If the wing is shaped, it's usually a flat bottom with some camber on the top. The thrown or launched models have very little camber if any, as too much camber and the pitching down moment becomes an issue because of the high launch speed (some times a rubber band catapult) compared to the gliding speed. The rubber band powered film over wire frame models do use camber, but fly at very slow speeds. F1D (very slow) model at 1:15 into this video: http://www.youtube.com/watch?v=MAmVFfnEdBY&fmt=18 F1D model at start of video: http://www.youtube.com/watch?v=5pOhbJPtPXM&fmt=18 |
| Mar30-09, 05:24 PM | #39 |
You say it doesn't make sense, but then you repeat it.
| Mar30-09, 10:24 PM | #40 |
I don't understand what you mean by the phrase "the least forwards". A wing does not accelerate the air forewards.
| Mar30-09, 11:09 PM | #41 |
Recognitions:
| Mar30-09, 11:26 PM | #42 |
Drag is related to shear stresses and pressure forces, not "forwards acceleration of the air". Just look at any video of an airfoil section in a wind tunnel, at no point is the air moving forwards.
Perhaps I take issue with your use of the word 'forward acceleration', I would call it 'deceleration of the air in the streamwise direction'. The air is being slowed down, not sped up. |
| Mar30-09, 11:41 PM | #43 |
Mentor
"Forward acceleration of the air" is technically correct, but it just sounds cumbersome.
| Mar30-09, 11:46 PM | #44 |
Recognitions:
| Mar30-09, 11:51 PM | #45 |
[tex]F=m\dot{V}+\omega x mV[/tex] Anyways, that's an odd frame of reference you choose to pick. I would stick to the wing of the airplane as your FOR from now on. Its the conventional way. scroll down to: " Carrying out the differentiations and re-arranging some terms yields the acceleration in the rotating reference frame" http://en.wikipedia.org/wiki/Rotating_frame I agree with what you said for the acceleration directions. It's just very awkward because in steady state flight you don't talk in terms of accelerations but velocity. I would have preferred that you said the air has a component of velocity down and aft, with the aft component reduced from that of the freestream. |
| Mar31-09, 02:06 AM | #46 |
Recognitions:
| Mar31-09, 04:25 AM | #47 |
A few years prior to WWI, Gottingen was experimenting with thick foils. He had a number of very thick and highly cambered teardrops. Some so radical they appear comical to modern eyes.
| Mar31-09, 08:23 AM | #48 |
Many thanks to Jeff Reid and Cyrus and everybody for exploring this interesting topic. I feel that I am learning quite a bit from this exchange.
| Mar31-09, 10:49 AM | #49 |
| Mar31-09, 11:19 AM | #50 |
Look, all Jeff is trying to say is that wings impart forward acceleration on the air mass. Forward acceleration does not have to mean forward velocity.
| Mar31-09, 11:22 AM | #51 |
![]() I'm saying 'forward acceleration' sounds very awkward. It's a local deceleration of the air. |
| Thread Closed |
| Tags |
| aerodynamics |
Similar discussions for: How did WWI Planes Fly?
| 3D Planes With D Value | Calculus & Beyond Homework | 3 | ||
| How do planes fly? | Mechanical Engineering | 7 | ||
| planes | Precalculus Mathematics Homework | 3 | ||
| planes | Introductory Physics Homework | 3 | ||
| planes | Introductory Physics Homework | 5 | ||
