| Thread Closed |
The Universal Geometric Set |
Share Thread | Thread Tools |
| Jun13-04, 09:07 PM | #18 |
The Universal Geometric Sethttp://mathworld.wolfram.com/VennDiagram.html Actually, spacetime does not really need to be "sliced up" in that it can proceed in discrete steps, yet, still be continuous. [density 1]--->[density 2]--->[density 3]---> ... --->[density n] [<-[->[<-[->[U]<-]->]<-]->] Intersecting wavefronts = increasing density of spacelike slices As the wavefronts[circles/Venn diagrams] intersect, it becomes a mathematical computation: 2, 4, 8, 16, 32, 64, 128, 256, 512, 1024, ...2^n If the universe includes everything that is real and excludes that which is not real, then the universe is the "Universal" set. You cannot refute the above logic... |
| Jun14-04, 07:37 AM | #19 |
Recognitions:
Since when is a simple closed curve necessarily a circle? As you aren't the ignorant one you must surely know that in order to demonstrate all the possible intersections of 4 sets in a venn diagram you cannot use circles. Moreover, surely you, still not being the ignorant one, must also recognise that a venn diagram is not an element of itself, and thus to take the definition you give, and then deduce that a venn diagram is a circle is most definitely not a logical conclusion?
They, circles and closed curves in the plane, certainly aren't even isomorphic, using your particular definition of isomorphic which appears to mean related be some affine transformation when embedded in the plane. But Im the ignorant troll, so what do I know about affine transformations? Proved Fermat's last theorem yet? |
| Jun15-04, 03:46 AM | #20 |
| Jun15-04, 07:06 AM | #21 |
Recognitions:
Gee, are circles really closed simple curves? you'd have thought they'd have told me that at university. especially after i had to prove the jordan curve theorem....
a closed simple curve is not necessarily a circle a square being a simple closed curve that isn't a circle, an ellipse also being one, which is what you claimed, and what i pointed out was incorrect, which led you to call me ignorant... hmm, i always take preverse pleasure in being insulted by someone who can't understand a implies b is not equivalent to b implies a. moreover your statement that a venn diagram is a circle is still incorrect, and now we've seen even more things you don't understand. |
| Jun15-04, 12:26 PM | #22 |
You mean to say, not all simple closed curves are circles. Wake up.
| Jun15-04, 12:34 PM | #23 |
He's right, Venn diagrams aren't circles. The definition of a Venn diagram that you quoted doesn't imply that they are, either. The definition of a Venn diagram refers only to the topology of the curves. The definition of a circle, on the other hand, is the locus of all points (x,y) that are equidistant from a fixed point (h,k). They don't mean the same thing. Why can't you just accept that bit of correction? |
| Jun15-04, 01:07 PM | #24 |
Here is what matt ...said: In nature, a sphere is the most energy efficient configuration. A 2D slice of that sphere is is a circle. Yes, I accept correction. But what is the point of arguing and pedantic "nit-picking" over definitions? |
| Jun15-04, 01:33 PM | #25 |
http://www.math.ohio-state.edu/~fied...55/Jordan.html
If the physical universe includes all that exists and excludes that which does not exist, then by definition, the universe is self containing. A dynamic process. |
| Jun15-04, 01:40 PM | #26 |
edit: fixed a quote bracket |
| Jun15-04, 02:14 PM | #27 |
Recognitions:
You are subjectively claiming I am nitpicking; perhaps there is another interpretation? Seeing as you managed to misunderstand almost everything that has been written, including failure to understand the important mathematical usage of the word 'necessarily', i'm not going to overly worry about your opinion about what constitutes a 'nit'. Add in to that the fact that most of your own posts are off topic in your own thread...
| Jun16-04, 04:35 AM | #28 |
I disagree. [1.] "A simple closed curve is not necessarily a circle" [2.] "Not all simple closed curves are circles" [1.] and [2.] are different. Not exactly equivalent. [2.] better fits the context of THIS thread. That which is not a member of the set is excluded[outside] of the simple closed curve, i.e. a curve that is not necessarily a circle but it does have the property of closure. ...I hope you understand. Didn't Ed Witten recieve the Fields medal of mathematics for work he did in mathematical physics? Physics would not exist without mathematics. Geometry can be expressed in terms of algebra. Einstein was very close to a "unified field theory" explained in terms of geometry. Here is the relevant quote: http://physicsforums.com/showthread....uantum+gravity You refuse to let the horse out of the starting gate. |
| Jun16-04, 04:37 AM | #29 |
So you promise to go harrass someone else? Thanks. |
| Jun16-04, 08:06 AM | #30 |
| Jun16-04, 01:38 PM | #31 |
http://www-groups.dcs.st-and.ac.uk/~...ns/Witten.html |
| Jun16-04, 06:29 PM | #32 |
Recognitions:
I promise to harass you whilst you are spouting inaccurate garbage, Russell, don't worry. Why on earth you chose to cite Ed Witten is a mystery, but then you seem to be beyond the pale of reasonable logical thought and into the realms of the crackpot, so frankly who cares?
| Jun16-04, 07:23 PM | #33 |
| Jun17-04, 12:23 AM | #34 |
A______B ____P____ C______D A, B, C, and P are "co-moving" i.e. they are at rest with respect to each other. The radius[hypotenuse] from P to the other points{A, B, C, D} is the same length. An expanding circle of light[from point P] reaches A, B, C, and D, "simultaneously". The invariance of "c". There is no experiment unless "numbers" can be attached to the quantity being observed. Your statement that "experimental physics is not mathematical" is total hog-wash. Any measurement uses numbers. Light cones are cutting edge stuff : http://www.mpi-hd.mpg.de/ilcac/98SPeter_prop/node4.html |
| Thread Closed |
| Thread Tools | |
Similar Threads for: The Universal Geometric Set
| universal gravitation | Introductory Physics Homework | 2 | ||
| Universal Expansion | Cosmology | 11 | ||
| universal law of gravitation | Introductory Physics Homework | 1 | ||
| geometric series/geometric progression | Precalculus Mathematics Homework | 2 | ||
| Universal Sequence | Brain Teasers | 3 | ||
