| Thread Closed |
0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current |
Share Thread | Thread Tools |
| Mar31-09, 09:22 PM | #1 |
0.5 volts is maintained across a 1.5 meter tungsten wire that has a cross-sectional area of 0.6 mm2. What is the current in the wire? 2. Relevant equations Resistivity of tungsten: 5.6E-8 ohm meters. Current Density: [tex]J = \sigma \cdot \frac{V}{l}, J = \frac{I}{A}[/tex] Definition of resistivity: [tex]\rho = \frac{1}{\sigma}[/tex] Variable meanings in equations used: I: current in amps, A: cross-sectional area of wire in m2, [tex]\sigma[/tex]: material conductivity, V: volts, l: length of extruded cross-sectional area (in this case, a wire) in meters, [tex]\rho[/tex]: resistivity in ohm meters 3. The attempt at a solution Using the relations and data available it seems to make sense to find the current in the wire by relating the known tungsten resistivity to the two definitions of current density in which most variables are known except for the I (current) that I'm after. Doing this yields: [tex]\frac{I}{A} = \sigma\frac{V}{l}[/tex] [tex]\sigma = \frac{1}{\rho}[/tex] [tex]\frac{I}{A} = \frac{1}{\rho} \cdot \frac{V}{l}[/tex] [tex]I = A\left[\frac{1}{\rho} \cdot \frac{V}{l}\right][/tex] Then I plug and chug: [tex]I = 0.6\left[\frac{1}{5.6E-8} \cdot \frac{0.5}{1.5}\right] = 3571428.571[/tex] Amps However this answer is not valid. Can anyone see something I am doing that is outright wrong? Invalid logic somewhere? Any hints to get me on the right track would be greatly appreciated. Thank you for your time. |
| Mar31-09, 09:35 PM | #2 |
Your answer has the right procedure but the area is in mm^2 you need to convert it to m^2. So you are off by a factor of 10^6 meaning 3.57 amps.
Below is an easier way to go about the problem and attain the same answer. resistance = (resistivity*length)/cross sectional area in m^2 Current = voltage/ resistance |
| Mar31-09, 09:39 PM | #3 |
Nevermind, lol, solved my own problem. Found out that I didn't convert millimeters squared to meters squared. Got it right now :)
| Mar31-09, 09:42 PM | #4 |
Thanks for the reply fball558 :) It's nice to get other views while your pourin over pages and pages of physics :)
| Thread Closed |
| Tags |
| volts current wire |
| Thread Tools | |
Similar Threads for: 0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current
| Wiring question: Going from larger wire to smaller wire | Electrical Engineering | 11 | ||
| How to find total energy from a current-carrying long straight wire. | Introductory Physics Homework | 0 | ||
| Current in a Wire. | Introductory Physics Homework | 5 | ||
| Finding diameter of a wire based on the current and current density. | Introductory Physics Homework | 1 | ||
| Aluminum wire, current, voltage, density, find mass | Introductory Physics Homework | 5 | ||
