Thread Closed
Calculate the individual flow rate - based on the pressure drop?
Share Thread
Apr3-09, 05:11 AM   #1
Hi
I have to calculate the flow rate inside two systems, which got water from the same “source”.
It is for a project with a pressure vessel with heat transfer arrangements, cooling coils inside the pressure vessel, and “jacket” system outside the pressure vessel.
Something like the one on this picture: http://www.postmixing.com/mixing%20f...ly%20large.jpg and the jacket system: http://www.cheresources.com/jacketed..._design3.shtml
I can calculate the pressure drop for every jacket- and coil-module, and it must be the only factor that “set” the individual flow rate, or what?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Thread Closed
Tags
coil, flow, flow rate, jacket, pressure drop
Similar discussions for: Calculate the individual flow rate - based on the pressure drop?
Thread Forum Replies
how to use flow rates (GPM) and pressure drop to determine if a valve is usefull General Physics 7
how to calculate outlet dia for required pressure drop in case of compressible fluid? Mechanical Engineering 6
Formula to Calculate drop Pressure in Liquid Pipe Materials & Chemical Engineering 4
Flow rate and back pressure Mechanical Engineering 2
converting pressure to flow rate Introductory Physics Homework 4
